First post, by Jackhead
- Oldbie
I tryed today get my Joystick (MS Sidewinder Precision Pro) working under DOS for WC3.
First at all i use a CT2230 SB16 card, the Jumper on the pcb is set.
I remember on the AWE32 (DOS) driver you can set the Gameport, test for conflicts etc..
But the SB16 driver has not such exe. The diagnostics also have no option to set/test the Gameport.
Also for DOS in the autoexec.bat do i have to set the Gameport? Like J200 ?
Any creative tool i can use to do Gameport adjustments for my sb16?
