ux-3 wrote on 2024-09-07, 15:14:
I did find a video where someone claims that one pin of the battery is on a real pin of the chip and you only have to drill one hole.
The negative side of the battery (at pin 16) is connected to the standard ground (at pin 12), so no need to drill that hole. The positive side of the battery (at pin 20) is not available from outside, so drilling is required. There are mainboards that actually provide an option for a CR2032 holder (e.g. the Shuttle HOT433) that connects to pin 20, so if you drill the hole there and attach a pin, you can power the Dallas chip from the board. I managed to drill or grind a trench at pin 20, break the connection to the internal battery and solder a pin pushed from the backside of the board to the Dallas module without desoldering it from the board.
