First post, by radek
I cannot switch to fullscreen in Debian 12. For some reason, Alt-Enter makes a window of the same size as the windowed DOSBox in the edge of the screen. The contents of the new window seems to be scaled correctly (it is a part of the windowed DOSBox contents). Moreover, DOSBox is hanging. Luckily, you can Alt-Enter back and close the window (using the 'x', keyboard is hanging).
It is completely new, DOSBox worked perfectly until now. I have tried to change to "machine=vgaonly", different options for "output", and starting with fullscreen directly. Nothing helps.
What is it all about?
Reply 1 of 2, by dominusprog
Try DOSBox Staging.
https://www.dosbox-staging.org/releases/linux/
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 2, by radek
fullresolution=desktop seems to work somehow. I shall see. My current changes in dosbox.conf:
output=opengl
