First post, by gulikoza
Hi Paul 😀
I know you're busy with psVoodoo (great work btw!), but I found some time to update my openglide-sdl patch to current cvs. Uses a seperate dir in the platform subdirectory and only updates 2 files. The patch is quite simple & it compiles in both windows & linux. I haven't updated project files (dunno, can VS6 have different source files depending on which configuration is selected?) since that might be some more work. I thought linux makefiles could be updated to detect if SDL is on the system and then decide to build a native or SDL version...also it would be great if the whole autoconf/configure/make stuff would work on MinGW as well but I have little experience with that.
Feel free to post your thoughts 😁
    openglide-sdl.diff
    3.33 KiB
    1222 downloads
