First post, by BEEN_Nath_58
I was pretty upset having to fire up Windows 98 anytime to launch AH-64D Longbow. However I recently discovered the Anthology version of the same game works fine.
Mixing the games, I noticed: replacing the lbwin.exe, wrapdll.dle files on the hard disk, and the MOVIES1.TRE file on the CD (I had to use a custom ISO for that) of standard Longbow with Anthology Longbow, the game would work fine.
I wonder if it is possible to look at the former two files, follow the execution and then patch, replace, NOP some things to make it bear the videos successfully?
Reply 1 of 2, by myne
Seems like more effort than zipping the files into a defacto patch.
My guess is that the anthology was simply compiled on a newer visual studio, so the files might be more different than a few nops could fix.
I built:
Reply 2 of 2, by BEEN_Nath_58
myne wrote on 2024-09-12, 00:51:
I am not sure: only one .dle (.dll?) amd one executable changes and so does the video format of encoding. There can be many changes outside of what I tested, so its easier if someone tests the game.
Also there comes out an additional "low memory" error on exit
