First post, by ldare
Hi,
I need to use a piece of dos based software and hardware via serial port that only works on PCs slower than 233mhz.
I have dual boot Win XP and Dos 7.1
The PC can see the hardware from DOS 7.1 but not via Windows XP.
I have tried DOS Box from Win XP but the software couldn't see the hardware.
Is there a version of DOS Box that will run on Dos 7.1 ?
Many Thanks
Lou
Reply 1 of 4, by eL_PuSHeR
Edit dosbox.conf and look for some statements resembling something like this:
[directserial] # directserial -- Enable serial passthrough support. # comport -- COM Port inside DOSBox. # realport -- COM Port […]
[directserial]
# realport -- COM Port on the Host.
# defaultbps -- Default BPS.
# parity -- Parity of the packets. This can be N, E or O.
# bytesize -- Size of each packet. This can be 5 or 8.
# stopbit -- The number of stopbits. This can be 1 or 2.
I think you need to enable it and give it proper values.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by ldare
Hi,
Just tried that. checked win xp com port 1 settings and put in
directserial=true
comport=1
realport=COM2
defaultbps=9600
parity=N
bytesize=8
stopbit=1
But the software in DOSbox still couldn't see the hardware on my com port?
Thanks
Lou
Reply 3 of 4, by ldare
Tried both com 1 and 2 just incase....
directserial=true
comport=1
realport=COM2
defaultbps=9600
parity=N
bytesize=8
stopbit=1
directserial=true
comport=1
realport=COM1
defaultbps=9600
parity=N
bytesize=8
Both didn't fix it
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
uhm look at the patches section of the forum
there is something with a improved serial port
Water flows down the stream
