NBA Live 95
First post, by milicognj
NBA Live 95 does not start at all. I installed it with SB PRO, SB 16 and with NO SOUND and there is no difference (obviously this is not the problem).
When I start the game only blank screen appears.
Reply 1 of 46, by milicognj
When started with DOSBox debugger there is a message which is writen for many times.
INT10: PutPixel unhadled mode type 4
Is this some graphic mode unsuported gby DOSBox?
If it is will it be supported in future?
If this is not a DOSBox unsuported stuff what could it be?
Ognjen Milic
Reply 2 of 46, by Qbix
Rank DOSBox Author
DOSBox Author
usually it's an error message printed by the game in vesa mode using bios calls.
Water flows down the stream
Reply 3 of 46, by milicognj
Game is still broken, but now DOS4GW reports error. Screen capture in the attachement.
    72.91 KiB
Reply 7 of 46, by milicognj
I have binded dos32a with game but the result was the same.
I don't hav debugging version of the dosbox newest cvs build and
I can't compile the source with minigw.
Ognjen
Reply 8 of 46, by HunterZ
You shouldn't need to bind it, and if it was working you would get a different error than "DOS/4GW..."
Try:
dos32a gamename.exe
Where gamename.exe is whatever you normally run to start the game.
Reply 9 of 46, by milicognj
I wanted to say that game does not work with dos32a too.
Binded or called within command line the screen is blank, and after few seconds dosbox windows are closed.
DOSBox console reports ilegal read from several addresses, and
Stack segment zero
Ognjen
Reply 10 of 46, by milicognj
The error is caused because of unhandled Interrupt service
INT 15 AX = BFDE BX=8
This is som undocumented DVDOS4GX.dvr service
Shouldn't this service routine been loaded upon loading the DOS4GW?
Ognjen Milic
Reply 13 of 46, by wd
Rank DOSBox Author
DOSBox Author
Yes 😀
Desqview is an application, i think it supported multitasking of
dos programs.
You could try to see what's happening at the int6, which opcode
triggers it (maybe posting the disassembly around it).
Reply 14 of 46, by milicognj
While debugging I came to very obscure behaviour.
When procedure returns i return on address where are only
zeros (code hasn't beeen written in here yet).
I'll try to figure out why.
Do You have any suggestions?
Ognjen
Reply 16 of 46, by milicognj
Something have definitely gone wrong with stack. That return address is part of file name wich is pointed by ESP.
Ognjen Milic
Reply 17 of 46, by milicognj
Interesting. It is probably the bug in the game.
The string with the file path c:\igre\sport\nba95\install.dat
overwrites the return address. Probably the space for it is staticly determined just by subtracting esp, but maybe something goes wrong during string length determination.
Game succesfully starts from lower directory (c:\igre\nba95).
Could this be a DOSBox error?
If this could be I will search more.
Ognjen Milic
