First post, by legodude
I have at least 13 vintage computers in my office which have sound and I don't like having to plug and unplug audio cables. I have a Hart Just Mixer which helps, but is limited to 3 inputs.
Anyone have a good mixer recommendation with the following specs:
-6+ inputs
-Smallish - 1u rackmount or similar form factor would be great
-3.5mm or RCA inputs. 1/4" *stereo* is acceptable as I can use a bunch of 3.5mm to 1/4" adapters
-Not just a switch.
Reply 1 of 4, by SScorpio
If you aren't using looking to do professional recordings with them, there are very cheap 4, 6, 8, up to 10 channel mixers readily available. They aren't rack mountable but they are under a foot side so they are very small. I daily drive a four channel one and it works fine.
https://www.amazon.com/COKYISS-10-Channel-Sub … /dp/B0D6367BYV/
Reply 2 of 4, by Shponglefan
13 sound sources is a lot, especially if they are all stereo (26 channels total).
Something like a Behringer RX1602 or an ART MX822 are 1U rack mixers that can handle up to 8 stereo devices. If you wanted to hook up more, you'd need at least one additional mixer for sub-mixing. You could also use a patch bay, though that would involve some manual cable switching depending on how you set it up.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 4, by legodude
That "Cokyiss" mixer is exactly what I was looking for. I don't know how I missed it searching amazon and google, but that should do it.
I even like the jack placement much more than my Hart mixer
Reply 4 of 4, by BloodyCactus
look for a Rolls RM203X, 10 stereo line ins, 1u rack.
