First post, by vlad54rus
Warcraft 3 v1.26a
WC3_FPSUnlocker mod
dgVoodoo2 2.82.3
Whenever is use dgVoodoo2 together with WC3_FPSUnlocker - the game no longer recovers from Alt-Tab. No such issue if I use dgVoodoo2 or WC3_FPSUnlocker alone. What could be causing it and how can it be fixed?
I did ask the author of WC3_FPSUnlocker about this bug, but he brushed it off as a dgVoodoo2 problem.
Reply 1 of 3, by vlad54rus
Tested again with dgVoodoo2 2.83.1 with debug logging enabled. Looks like the game tries to re-create swapchain with 500Hz refresh rate, somehow it works on native d3d8 but fails in dgVoodoo2.
Reply 3 of 3, by vlad54rus
That's what I've been using in the past, but stopped after observing graphical corruption in some custom campaign maps.
dgVoodoo2 seems to deliver better performance than native OpenGL renderer + it has an ability to force borderless windowed with custom scaling, so I can play the game in 4:3 and still have seamless Alt+Tab.
Anyway, I've already worked around this issue by overriding refresh rate via dgVoodooCpl.
