mx597 wrote on 2024-10-02, 05:45:
Can you tell us more about the provenance of the parts? For example, did the motherboard come with the DIMM modules you are testing it with? If so, do you know if this combination ever worked together before? If this is the case it would point to a "new" hardware problem that developed at some point (bent pin, bad cap, etc.)
It would also be good to know what chips are on the DIMMs (the first line of numbers on a chip IC is generally the model number) and number of those chips per DIMM - and if there is any difference between behaviour depending on which slot a DIMM is inserted into.
If the motherboard and the DIMM modules come from separate sources and have never worked together before, it's more likely to be a compatibility/speed issue (like pete8475 pointed out).
Possibly, but given the numbers I'm not so sure. i440BX can handle chips up to 128Mb, so for a 128MB DIMM to get recognized as 64MB, it would have to have four 256Mb chips, probably 16Mx16. That's theoretically possible but it would make it a very unusual DIMM. I'd say particularly given the complete failure to boot with 3 DIMMs installed regardless of order, some physical damage to the board matches the description better.
