First post, by smesgr
- Newbie
Hi,
I (again) have an issue with my EPoX EP-MVP3C after replacing the buck converter the board was working several month and does not boot anymore.
The issue:
- 3.3V & 5V is there
- POST code shows "--"
- Voltage regulator for the CPU (Q10 on image) does not provide selected voltage
- LM2636 has VCC and Boost Voltage, VIDs are set correctly to (in this case 2.8V)
- Output Enable of LM2636 floats around 1.5V to 2V. According to Specification this is near the disable trigger point
If you power on/off several times - there is a chance the system boots, Voltage regulator provides the requested voltage and the system is running some seconds before voltage is dropped and the system hangs. Thus I think the output enable circuit is to blame. But I can't figure out where the traces are going. Has anybody an idea?
The OE pin 19 on LM2636(U15) is connected to 10k resistor R176 and Q11 (likely a NPN - top pin - likely collector pin). One of the Q11 pins goes to R175 and R174 and than to the socket. But I couldn't find any connected pin. The other Q11 goes to GND. R174 and R176 are connected to 5V. Between R174 and U15 is also a Via which i couldn't figure out.
In the picture R174 is missing because i cracked it while probing something
