First post, by Boot_8046
Hi! So as the title says there's an undisclosed modification for Socket 423 to 478 adapters to support Northwood chips (obviously only 400MHz FSB ones).
An ebay seller which sells PC-CHIPS made socket adapters claims he can mod them to support Northwoods, but is not willing to disclose said mod to the public.
He's selling one modded adapter for 150$ which in my eyes in ludicrously overpriced so I'm planning to buy one and show said mod to the community.
I can't buy said adapter yet but I created this thread now to raise awareness to this mod (Hope it's okay) - it reminds me of the Tualatin on 440BX modifications floating around. 😀
This thread will be a journal of mine, I'm all for disclosing such mods with the community and open sourcing such things. Cheers!
Reply 1 of 12, by BitWrangler
I don't think they would need much. Maybe just a voltage, vid pin tweak. A decade plus back, friend of family had a compaq desktop, socket 478 but willamette CPU, I think the stuff we could find on it at the time said it was willamette only. That might have just been the 400 bus, but anyway, we'd scraped up a 2.4 Northwood to try, stuck that in and it booted, but at 1.8Ghz because board didn't support 533. Left it like that because it was better than the 1.6 willamette anyway. Seemed to do fine a few years until bloat caught up with it. Maybe some situations might need the FID pins insulated or something in case the motherboard or CPU cares it's seeing the wrong thing.
Reply 2 of 12, by stamasd
Likely only a voltage mod, as AFAIK apart from the lower core voltage and the larger L2 cache there aren't any significant differences between Willamette and Northwood.
(at least not the first generation Northwood with 400FSB)
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 3 of 12, by VivienM
stamasd wrote on 2024-10-04, 18:36:
Would it need a modded BIOS?
Reply 4 of 12, by Trashbytes
One like this ?
Yes it works, its even identified correctly by the BIOS and runs at 2.6.
The attachment QDI PlatiniX 4X.jpg is no longer available
The attachment 478 to 423 adaptor.jpg is no longer available
Bought it a few years ago from eBay, I dont use it often as the system to attach a cooler to it needs to be replaced. IIRC ASUS also had a Motherboard and adaptor that worked in a similar manner, the adaptor wouldn't work with any other board but did allow up to 2.6 Northwood CPUs to run.
Reply 5 of 12, by Boot_8046
Trashbytes wrote on 2024-10-05, 01:42:
One like this ? […]
One like this ?
Neato! Are ther any visible modifications on the adapter?
Reply 6 of 12, by Boot_8046
I think it'd be a bit more involved than a simple VID pin mod. I have a D850MV board (i850 with S478) and my POST analyser displays -- when i plug in a Northwood CPU. Apparently Northwoods are supported on newer revisions of this board but not on mine.
It can also not work because it's an Intel board, they always lock their BIOSes down to a tee.
Reply 7 of 12, by Trashbytes
Boot_8046 wrote on 2024-10-05, 09:23:
One like this ? […]
One like this ?
Neato! Are there any visible modifications on the adapter?
Ill try and dig the board out and take some pics, pretty sure the BIOS on this board has been modded to have Northwood microcodes, its an i850 board.
Reply 8 of 12, by stamasd
Trashbytes wrote on 2024-10-05, 09:44:
Speaking of which, would you mind sharing that modded BIOS? I have a PlatiniX 4x motherboard (currently with a Willamette 1.7 in it) and might want to give it a go some time. 😜
I also have a 478-to-423 adapter, which I've only ever used with a s478 Willamette, never thought of trying it with a Northwood.
(I don't know much about that adapter of mine, it came with a s423 PcChips motherboard I randomly picked on ebay a few years back)
I/O, I/O,
I/O, I/O
Reply 9 of 12, by Boot_8046
stamasd wrote on 2024-10-05, 17:31:
Speaking of which, would you mind sharing that modded BIOS? I have a PlatiniX 4x motherboard (currently with a Willamette 1.7 in […]
I might be able to do that for you, what's the exact model of the mobo?
Reply 10 of 12, by Paadam
Powerleap used to make S423 to 478 adapters, back in around 2007-2008 I used one on Gigabyte GA-8TX with a 2.6 GHz Northwood (400 MHz FSB) and it worked without any problems.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 11 of 12, by stamasd
Boot_8046 wrote on 2024-10-08, 14:38:
It's precisely this one: https://theretroweb.com/motherboards/s/qdi-p6 … p4x-platinix-4x
I/O, I/O,
I/O, I/O
Reply 12 of 12, by Boot_8046
stamasd wrote on 2024-10-08, 22:14:
There's no bios image available on TRW, xan you dump yours please?
