First post, by SGM
I got this vintage monitor from 1990s (I can only guess that it was made around 1994-1995), but there's no brand labels, names, stickers. Only a general data sticker on the back. I searched the net, couldn't find anything based on those model numbers and ID codes.
Maybe some of you have seen something like this? All I can tell, it seems to be "manufactured" by an European (German) company, although "Made in Malaysia".
The reason I care about that is its technical specs. What's its maximum supported resolution, refresh rate, and so on.
I took some pictures of it, including the back sticker.
Pentium MMX 200 (at 166MHz), 64Mb, 2Gb (CF), AWE32, S3 Virge DX/GX, 14" CRT, Win95.
Pentium 3 at 700MHz, 384Mb, 16Gb (CF), AWE64, Radeon 9200, white 15" LCD, Win98SE.
Toshiba 320CDS: Pentium MMX 233, 32Mb, 2Gb (CF), slow LCD, Win95.
Reply 1 of 11, by weedeewee
When an FCC ID is present it can often times lead to some useful information, though not always.
in this case it leads to https://fccid.io/AMPJD144
which just mentions
Jean Co Ltd Color Monitor Maximum resolution: 1024 X 768 non-interlaced. JD144
enjoy
Do not ask Why !
Reply 2 of 11, by SGM
weedeewee wrote on 2024-10-05, 06:59:
When an FCC ID is present it can often times lead to some useful information, though not always. […]
which just mentions
enjoy
Wow! How did this page work for you? 😁 I tried the same thing yesterday and it found no results with Grantee Code: AMP and Product Code: JD144.
Much appreciated!
Reply 4 of 11, by AppleSauce
The attachment Screenshot_20241005-170937_Chrome.jpg is no longer available
Seems to have all the specs and stuff.
Reply 5 of 11, by dormcat
AppleSauce wrote on 2024-10-05, 07:10:
The four variants differ in...... "Container Loading 20' / 40'"? Never seen a company lists its product specs with how many units a container can load up until now.
Reply 6 of 11, by AppleSauce
dormcat wrote on 2024-10-05, 07:26:
Not sure thats pretty odd , maybe to help inform companies buying palettes of them? , but I'm pretty sure they'd tell them that stuff in private.
Reply 7 of 11, by SGM
It does show my JD144F there, at least I know the supported resolution. But I can't find the maximum refresh rate it can handle, the default 60 Hz gets on my eyes. I remember in the 90s I had a small software piece which allowed me to use 75-85 Hz on Win95 (the monitor itself was from the same era as this one here, same size, but a different model). A friend's computer didn't support it, my attempt to get the refresh rate higher resulted in totally messy graphics that looked like a colorful and fast moving woven rug.
So I guess I'll just try it. 800x600 resolution is plenty fine for a 14" display, I hope I can get it to 75 Hz, and that it won't damage the CRT itself.
Reply 8 of 11, by mkarcher
SGM wrote on 2024-10-05, 08:24:
If a monitor is specified as "1024 x 768 non-interlaced" without any mention of a refresh rate, it is quite likely that the monitor supports only 60 Hz at that resolution, at a horizontal frequency of 48kHz. The good news is: This kind of monitor usually supports 800x600 at 72 Hz or 75 Hz as well, as these modes do not exceed 48kHz horizontal frequency, which can yield a nice flicker-free image. If your Windows 95 graphics driver is nice, it will offer these refresh rates in the advanced settings panel of the display properties. If you can't get Windows 95 to change the refresh rate at 800 x 600, try looking for a DOS setup utility for your graphics card that can be run from AUTOEXEC.BAT to set the default refresh rate for certain modes/resolutions.
Reply 9 of 11, by weedeewee
Dang, I know I could look it up... :-p , what's the formula again ?
Horizontal frequency is listed, 30 to 50 kHz
Vertical frequency is listed, 50 to 90 Hz
and bandwidth is listed, 70 MHz
ok so pretty basic & way off it seems Hpixels * Vpixels * refresh = dotclock (bandwidth)
but
visible Hpixels & Vpixels are 1024 x 768 ,
yet there's invisible ones that include the front porch, backporch, sync puls etc...
Hpixels 1344 * Vpixels 795 (blatantly stolen from the standard modeline calculator)
so max refresh, according to specifications on this monitor at 1024x768 would be ... . around 65 Hz
edit: max refresh for 800x600 would theoretically be 103Hz, but since the max for the monitor is specified as 90Hz, I'd keep it at 90Hz max @ 800x600
oh yeah missed the max Hfreq . meh, stick to what mkarcher said 😀 (max 79 ~ 80Hz)
Do not ask Why !
Reply 10 of 11, by PC Hoarder Patrol
Only one specified is 1024x768 @60Hz - https://web.archive.org/web/20020414160506id_ … ain/spc-14c.htm
The attachment Jean JD144 series.jpg is no longer available
Reply 11 of 11, by SGM
PC Hoarder Patrol wrote on 2024-10-05, 10:43:
Someone calculated here, at 800x600 it should handle 75 Hz too, even if it can't do that at 1024x768. 😀
EDIT:
I finally installed the ATI Rage II driver (I finally found it online) and now my Windows 95 runs at 800x600 @75Hz with that CRT monitor, True Color, all quite nice and feels nostalgic. 😀
