First post, by BEEN_Nath_58
As the title says, I am looking for file managers, that work on OS as old as Windows 95 and on the latest OS. The point is to use it to launch InstallShield on games that demand a Windows 9X environment, while the executable file for the InstallShield doesn't apply any compatibility setting on it even when set.
The first name that comes to mind is Total Commander.
What are the others?
Reply 1 of 19, by Grzyb
FAR ?
File Commander ?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 19, by Joseph_Joestar
Total Commander.
It even has an older 16-bit version which works on Windows 3.1 as well.
My retro stuff
Reply 3 of 19, by Turboblack
windows commander
old.net.eu.org - CMS for downgraders /// w10.host - WEB 1.0 HOSTING (small web) /// elpis.ws - ZINE about small web
Reply 4 of 19, by Azarien
BEEN_Nath_58 wrote on 2024-10-08, 10:10:
I'm not sure I understand this sentence. Do you want to set compatibility settings on a file manager, so that an exe will inherit those settings even if it doesn't have them set directly?
Reply 5 of 19, by myne
I think so.
In which case, good old fileman.exe from the 95 dir should do too
I built:
Reply 6 of 19, by BEEN_Nath_58
Azarien wrote on 2024-10-08, 12:03:
Correct. Since setting it on an InstallShield setup has no effect. It needs to be put on the temporary file IS creates when the executable is executed, however you can't expose the setting to set compatibility on a non executable file. Although it is possible to do it through ACT Windows XP, however it is still cumbersome
Reply 7 of 19, by myne
Tried fileman.exe?
Don't you just miss its' clunky simplicity?
I built:
Reply 8 of 19, by leileilol
I would avoid this idea altogether as they won't know how to deal with modern permissions and special characters.
Reply 9 of 19, by myne
That's what compatibility mode shims.
Basically, Beennath wants a launcher program that he can set to win95 compatibility mode.
Anything run from there will inherent the compatibility mode.
An old file explorer is the most flexible.
Which is why he asked, and I suggested fileman.exe.
The "explorer" from 3.x that made it into 95.
I built:
Reply 10 of 19, by Grzyb
myne wrote on 2024-10-09, 02:32:
fileman.exe
WINFILE.EXE
Reply 11 of 19, by BEEN_Nath_58
leileilol wrote on 2024-10-09, 01:28:
I haven't looked at places outside of Program files and the (x86) variant, nor did I look to install at places with more permissions (where could they be?).
Maybe the old File Managers may have issues reading foreign character set, but at present I don't have such a game to test.
Do you have a better idea?
Reply 12 of 19, by BEEN_Nath_58
Turboblack wrote on 2024-10-08, 10:18:
windows commander
Is Windows Commander the same as Total Commander? At least that's what Google gives
myne wrote on 2024-10-08, 12:09:
I think so.
I don't have Windows 95 on hand now, would be able to share the FILEMAN.EXE?
Grzyb wrote on 2024-10-09, 03:06:
WINFILE.EXE
Grzyb wrote on 2024-10-08, 10:13:
FAR ?
File Commander ?
Worked quite fine, thanks!
Reply 13 of 19, by myne
Got 98/me?
Should be in there too
I built:
Reply 14 of 19, by marxveix
The Doszip Commander is an LFN-aware TUI file manager (NC clone) with built-in Zip and UnZip for DOS and Windows.
https://github.com/nidud/doszip
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 15 of 19, by Cyberdyne
https://betawiki.net/wiki/Windows_95_20_July_1992_build
There is a nice WINFILE.EXE replacement there, called FILEMAN.EXE. It is same thing with added right mouse click functions. It works with normal Windows 3.1x and so on.
Reply 16 of 19, by zyga64
marxveix wrote on 2024-10-09, 06:44:
Dos Navigator has also its modern continuation for multiple operating systems (DOS, Windows x86, Windows x64, Linux, etc.) : http://ndn.muxe.com/download/
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 17 of 19, by Grzyb
BEEN_Nath_58 wrote on 2024-10-09, 06:13:
Yes, at certain point Windows Commander got renamed to Total Commander, as "Windows" was a registered trademark.
Reply 18 of 19, by Azarien
zyga64 wrote on 2024-10-09, 07:53:
By the way, the DOS version of NDN is runnable but veeery slooow on my Pentium MMX 233 MHz, making it unusable on real DOS machines (and I can't imagine how it would work on a 486 for example).
Seems they don't test it on real hardware from the era…
Reply 19 of 19, by marxveix
Good to know, thanks.
