First post, by unterwulf
Just curious if there is already a maintained subj somewhere on the web. I tried to find it myself, but it's hard to google because there are mostly dos-related sites in search results not ones running on DOS servers.
Please post here any websites that you know are running on dos-based software.
So far I've found only http://brutmanlabs.org 😀
Reply 1 of 2, by GemCookie
floppy.museum is hosted on a 286 system running MS-DOS 6.22.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 2 of 2, by Turboblack
http://web1.0hosting.net/ - hosting which can be used under dos
also @mail and admin panel too
https://www.bttr-software.de/forum/board_entry.php?id=22015 some proofs
has its own content management system (like Wix, but works under DOS)
to work with CMS without hosting - you can use http://old.net.eu.org/
https://github.com/turboblack/HamsterCMS_nes_theme
graphic theme for backward compatible sites, works in DOS, windows 3.11 95-98-xp and modern
a little about the template - it was created in HTML 3.2, which means it will be displayed on very old browsers from the mid-90s and, of course, under DOS
new project - magazine about small web http://elpis.ws
works under dos in both graphic and text modes
old.net.eu.org - CMS for downgraders /// w10.host - WEB 1.0 HOSTING (small web) /// elpis.ws - ZINE about small web
