First post, by ReignerDeustcher
I can play fine almost all windows racing games with my xbox one serie s controller but this one have problems
the game detects the controller and i can map everything in the config but in the race the controller does nothing, not one button works
Reply 1 of 5, by wierd_w
Relevant.
https://github.com/CookiePLMonster/SilentPatchNFS90s
Possible community fix inside.
(NFS2SE) Fixed a bug preventing controller button mappings from working correctly with gamepads that report more than 15 buttons (such as the Xbox One controller).
(NFS Porsche) Fixed a startup crash due to DirectInput controller enumeration being broken under specific circumstances on Windows 10 and newer.
Reply 2 of 5, by myne
Tell me you only assigned 4bits to button codes without telling me you only assigned 4 bits.
I built:
Reply 3 of 5, by wierd_w
Look, it was an OPTIMIZATION to save FOUR WHOLE BITS in that bit flag variable!!!
/s
Anyways, the community fix above takes the form of a dinput wrapper library, and is universal for all NFS games, and may or may not work for the OP.
I hope it does.
Reply 4 of 5, by myne
Tbf, nfsp was what? 25 years ago?
I built:
Reply 5 of 5, by ReignerDeustcher
wierd_w wrote on 2024-10-11, 07:39:
Relevant. […]
Relevant.
it worked! thanksss 😄
