Dos packet driver
First post, by Cursed Derp
Heyyyyyyo,
Dos Quakeworld won't work cuz I don't have a dos packet driver. I got a 3com 3c905-tx pci nic. Any help would be greatly appreciated.
Thanks
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 1 of 6, by Grzyb
http://www.georgpotthast.de/sioux/packet.htm
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 6, by Grzyb
wierd_w wrote on 2024-10-11, 16:51:
This one seems to lack the packet driver?
Anyway, in case of problems with the latest driver, here are earlier versions:
Re: mTCP hangs..
Re: mTCP hangs..
Reply 4 of 6, by Cursed Derp
Get the 'etherdisk' for the 3c509 series. […]
905, not 509! Deeerp!
http://files.mpoli.fi/hardware/NET/3COM/3C90X.ZIP
Contains disks 1 and 2 of the etherdisk set. All of the DOS stuff for that series nic.
Darn I tried this and it crashed my pc in windows. Should I run it from dos? Should I put it in the autoexec or config? What command line parameters should I use? Sorry just trying to get some more info cuz I don't know anything about dos networking
Reply 5 of 6, by auron
the best overview of dos networking was on the freedos wiki. but it's down right now and archive.org doesn't work either, so read this and this. but really, even the documentation included with drivers from back then should be enough to set it up.
another useful thing is, there are tools like loadsys that allow you to load drivers even after booting, so you can for instance put this in dosstart.bat and just load the drivers when rebooting to DOS, instead of loading them every time in config.sys. just one option of course, you could also mess around with boot menus etc.
Reply 6 of 6, by Cursed Derp
auron wrote on 2024-10-16, 22:25:
Thanks that's awesome! I think the wayback machine works but everything else on archive doesn't. I'll check out the freedos wiki
