First post, by donny
Hi there,
I have an specific issue which I didn't find discussed in the past, please bare with me 😀
Situation:
- MS-DOS 6.22
- 486 MoBo ISA+PCI (DTK PKM-0033S aka GMB-486SPS)
- 128kb Cache
- CPU AMD-X5-133ADZ
- 16 MB FPM RAM
- CF-Card
- S3 Trio64 on PCI
- ES1868 based SB ISA
Game:
- Doom 1 Original (or Fdoom 0.9.9f)
Issue:
If Sound and Music are enabled, certain moving actions produce graphic stutter. (-> Like turning ones-self around own axis)
But: If sound/music is disabled, everything is fine whatever I do (or move).
The setup itself seems more than sufficient for the Game. Fdoom Benchmark in Demo1 hits the 35fps ceiling easily.
I tried some obvious things / thing I know from the past:
- Changing IRQs / looking for conflicts -> No change
- Fiddling with some BIOS settings like ISA-Clk, Cache, etc.
- Read about MPU-401 issues that may cause this -> Disabled MPU401 with "esscfg.exe" -> No change
- Univbe -> No Change
- Bare DOS without loading anything (F5 at start-up) -> No change
- playing around with "mode con rate=" as someone suggested to me...
What I'm looking for are more ideas on how to diagnose - and - best case - avoid this issue 😀
PS: If I remember correctly I even had Pentium 1 setups (133 MHz) in the past which had this issue. I simply didn't bother back then.
Thanks in advance.
Greets,
Sebastian
