First post, by Mr_Blastman
I'm sad. I love my Tandy 1000 RL and TX. Alas, my vintage Seagate 20 mb hdd is dead. RIP. She won't spin up. I hear the heads moving, but nothing spins. Gotek makes a very nice USB Floppy emulation device, so I can plug a usb stick in. But those are slow. And tedious. I want vintage 80s HDD speed. Are there any such adapters, similar in concept, where I can use a USB stick as a HDD on a x86 machine which plugs into the IDE interface?
I ask because on the Amiga scene there is such a device for SD cards. I wouldn't mind if this were SD on PC, either.
edit:
I can't edit the title, and realized I spelled adaptors wrong. This bothers me. Oh well. 🙁 Should be spelled adapters.
Reply 1 of 6, by Jo22
Hi! The Tandy 1000 RL has 8-Bit IDE?
If so, it might be possible to use Compact Flash cards or IBM Microdrives, maybe.
The obvious choice, XT-IDE has its trouble with Tandy 1000 line, or so I heard.
Speaking under correction, though. I'm just a layman here. 🙁
Edit: Oh, there's another, almost forgotten alternative.
The DiskOnChip modules (DOC2000) can be used on 8-Bit bus.
Either via PC bus card or on an ethernet card. They appear like EPROMs.
They can be flashed with an plain 8088 firmware, even.
Here's a site with pictures: http://www.daupara.de/surfstation/
Reply 2 of 6, by Horun
Yes the controller and drive are XT-IDE, not compatible with AT-IDE devices. The onboard controller has to have a XT-IDE drive like st325x, stst351a/x or one of the wd "-x" drives like WD-93024-X.
With only one 8bit expansion you might be able to use a true 8bit AT-IDE adapter like a Low tech 8bit IDE (Lo-tech XT-IDE XT ISA) adapter and then a CF card + adapter....
Reply 3 of 6, by Mr_Blastman
Horun wrote on 2024-10-17, 02:09:
Ahh, yes, thank you both for the insight. Seems something such as this:
https://www.ebay.com/itm/285964268192?_skw=sd … ABk9SR6KfoYzTZA
Might work?
Now I must check if my old multi-Flash card reader will accept Compact Flash, that I bought years ago, to copy from the main pc...
Reply 4 of 6, by Jo22
Hi, I'm not sure. I'm not a Tandy 1000 owner, but I vaguely remember something about compatibility issues with the XT-IDE card.
It maybe needs a special firmware for Tandy computers or something along these lines.
Maybe a Tandy 1000 owner on the forums can help here?
Reply 5 of 6, by stamasd
I would recommend a SD card-to-IDE adapter. They can be had for a few bucks on amazon or ebay, and then you can use a regular SD card plugged into the IDE bus.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 6 of 6, by Shponglefan
I've used a BlueTech Lava Systems XT-IDE CF card with my Tandy 1000 TL: Tandy 1000 TL Build / Restoration
I've also used a Lo-tech XTIDE card in my Tandy TL/2. I did have to reflash the BIOS (I vaguely recall memory location of the BIOS extension being an issue?).
The attachment Lo-tech CF adapter successful flash.jpg is no longer available
The attachment Tandy TL2 XTIDE success.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
