First post, by egbertjan
When I want to run The Need for Speed ​​- Special Edition and FIFA 97 on my dos 6.22 pc with a memory manager (Memmaker or netroom). No matter what settings in the memory managers, need for speed crashes at startup, the same goes for FIFA 97. If I undo the memory manager, both games work fine on my DOS 6.22 pc. Does anyone know how I can fix this with these 2 games. All other games and programs I run work fine with memmaker or netroom running
I have the following pc.
AMD k6 2 plus 500mhz
ASUS P5A-B rev 1.04
32mb sdram 100mhz
S3 Vrige dx 4mb
MSdos 6.22 and Windows 3.11
with 2 x Ide to sata converter with 2 x 850 pro ssd 128gb
see picture what goes wrong when starting Need For speed
The attachment 20241010_002428.jpg is no longer available
Reply 1 of 1, by dominusprog
Try the UMBPCI. Add these lines to CONFIG.SYS.
[COMMON]
DEVICE=C:\WINDOWS\HIMEM.SYS /V
DEVICE=C:\UMBPCI\UMBPCI.SYS
[MSDOS]
DOS=HIGH,UMB
FILESHIGH=40
BUFFERSHIGH=30,0
STACKSHIGH=16,256
https://www.uwe-sieber.de/umbpci_e.html
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
