First post, by ft1000923
So i'm in the middle of upgrading my childhood computer, which is a AcerPower Ft100 with a ECS Sf2/661fx motherboard, Celeron D 340, AGP Geforce 6200. Was planning on upgrading it as a retro build to play period accurate games, so i bought a Pentium 4 531 and a AGP Geforce 7600 GS (GV-N76G256D). GPU arrived today. However, after installation, the pc doesn't post anymore when a AGP card is installed (nor with the old 6200). Oddly, the 3 pin case fan also doesn't seem to work anymore. The computer still boots with just the onboard graphics though. Problem is, i don't have another AGP system to test it out, and tbh, I'm not sure i wana risk picking up another board just to also fry it if it's the new GPUs problem. Took a look at all the traces on the board and i can't seem to find any burn marks that might indicate a short of some kind. I'm kinda lacking in experience with socket 478 and older, but seem to recall some kind of issue with newer power supplies and weaker +5v rails. The one I'm using a BeQuiet 400w that can do 15a through the +5v rail. Any advice on whats going on, or am i screwed and need a new mobo?
