Cpu for 1155 XP build
First post, by vermillion
Hi , I have a few 1155 motherboards all Gigabyte GA-H61M-S2PV (rev 2.1) and i want to build a xp system. which Cpu would be best considering thermals, L3 cache, price and longevity.
I believe Sandy Bridge Cpu's are soldered to the ihs but Ivy Bridge use thermal compound, which i'm concerned will be dried out by now.
prices at present in the uk fo the cps's i have looked at are:
I7 3770k £50 tdp 77 watt l3 8mb
17 2700k £30 tdp 95 watt l3 8mb
i3 2130 £4 tdp 65 watt l3 3mb
or are there better recommendations.
Reply 1 of 27, by st31276a
Is thermal compound drying out and affecting performance really a thing?
My understanding is that the compound must only fill some very tiny imperfections between the cpu top and the heatsink bottom so that they touch perfectly, most gets squeezed out and what remains stays there, trapped. It only needs to flow when it is installed, thereafter it remains static.
I applied some arctic silver to my first dual xeon system in 2006 and it is still functioning perfectly 18 years later, running 24/7, never taken apart, no problems whatsoever. I only clip off the fans every couple of years to remove some fluff from the top of the heatsink fins, thats it.
Reply 2 of 27, by vermillion
st31276a wrote on 2024-10-22, 10:48:
I refering to the compound between the die and the ihs, as these cpu's are getting old. I do not want to delid a cpu as i will probibly kill it.
Reply 3 of 27, by st31276a
Yes I understand, I was only wondering if it would ever realistically become an issue.
Reply 4 of 27, by momaka
Based on what I have seen in previous similar threads on VOGONS, most will probably disagree with me here... but I really think i5 and i7 CPUs are an unnecessary overkill for a GOOD XP build. With that said, my personal recommendation is towards the i3's and Pentium G / dual core. Of course, it will all largely depend on what you intend to use the system for, too. If running really demanding games like Crysis is up high on your list, then the i5 or i7 might become a more sensible choice. Otherwise for just about anything else form the XP era, a high[er]-clocked i3 or Pentium G/dual-core should do just as well, since most XP era games rarely use more than 1 or 2 CPU cores. The i3 and P D-C/G also usually have much lower TDP (so will require less energy to run and run cooler too and/or not require any large/special/expensive coolers/heatsinks) and are cheap (can buy a few/many spares for the price of one i5 or i7.) Moreover, if your motherboard supports OC-ing, you might be able to get some really high core clocks... and again, without having to resort to expensive or large CPU coolers.
Yes.
But whether it will happen or not (or rather, how quickly) depends on a number of factors.
Prime factor is really the running temperature: the higher the temps at which the TC (thermal compound) is exposed to, the quicker it will degrade and/or dry out.
Of course, the amount of run time is also a factor, particularly run time spent at elevated/high temperatures.
Lastly, the heat differential between the two mediums that the TC joins can also be a factor. For example, if you have two CPU dies with the same TDP (thermal design power... i.e. heat output), but one has a die with twice the surface area of the other, then the CPU with the larger CPU die surface area will strain the TC less, because the amount of heat per unit of surface area will be smaller. This means smaller heat differential per surface area, so the TC will have "less work to do".
Like you, I also have systems where I never ever changed the thermal compound, some of which are over 20 years old now and with many hours of run time. But these are typically either low-TDP systems (Pentium 3 or Athlon 64) or higher-TDP systems with large coolers and fast running fans. So the end result is the same: the temperature of the heatsink (and CPU underneath) is kept low, so the thermal compound didn't dry out or age too badly. By low temperature, that would typically be under 60C at all times (preferably under 50-55C). And with my P3 systems, drying compound is never really a problem, because these typically operate at under 40-45C max... and that's with their fans running at reduced speeds to keep them a little more quiet.
Well, the thing is, nothing is "static", even if it appears to be so.
In case of CPU's, the heating and cooling causes all of the various materials the CPU is made from to expand and contract at slightly different rates. So while everything does appear to be static, there will always be micro-movements between various materials. In the case of thermal compound, this will mostly lead to the "pumping" effect, where any liquid substance in the compound may be pushed out while the "solids" remain stuck to the various surfaces. Over time, this is (IIRC) what causes TC to dry out.
st31276a wrote on 2024-10-22, 11:00:
It has.
There was a thread here on Vogons maybe a few months back (in the summer I think) where a user had an issue with an Athlon 64 CPU running at really high temperatures. Several different stock and non-stock coolers were tested, all yielding poor temperatures. The issue turned out to be a mix of a faulty core and bad TC between the CPU die and CPU IHS (probably the latter led to the former issue... i.e. the failed TC overheated the die, and that permanently damaged the internal temperature diode to always read higher than normal.) When the user delidded the CPU and changed the TC, the temperatures improved quite a bit (dropped around 10-15C IIRC), but were still overall high (~50C idle, which is a bit too much for an A64 Venice core CPU.) I'll see if I can dig the thread a bit later.
This hasn't been the only CPU I've seen with such issue. In fact, a recent encounter with this was over the summer when I built a retro PC with my nephew. We got a whole used PC as a base for the project. It was a Core 2 Quad -based build. During testing, we saw core #1 & 2 with the temperatures always being higher than cores 3 & 4, especially under load (almost 10-12 degrees Celsius worth of difference with larger CPU loads). Most likely the TC between the CPU dies/cores (1&2) and IHS was going dry... and I can't say I would be surprised if that really was the case, because whoever built the computer originally used one of those "low profile" Intel stock pushpin coolers that's really meant for 45nm Core 2 Duo's. It was obviously undersized for the TDP of the C2Q (8300) in the system, making it run hot all the time (~45-50C idle, 65-70C under heavy but not 100% load, IIRC). My theory is that this eventually lead to TC between CPU's IHS and cores 1&2 to dry out (the TC between the cooler and CPU looked like it was changed once or twice before... probably someone trying to figure out why the temperatures were still high.) We didn't de-lid the CPU to change the TC there due to time constraint, but I did give him a much larger cooler (3 heatpipe Arctic Freezer, IIRC). So with the new cooler, at least we were able to drop the overall temperatures of the entire CPU, which translated to cores 1&2 to also run a little cooler (though still consistently higher than 3&4). But at least no core(s) were at the verge of throttling under load anymore. Actually, cores 3&4 rarely broke the mid-50's Celsius, so that was a nice upgrade.
Reply 5 of 27, by vermillion
So a Cpu soldered to it's IHS May be better for longevity if you do not wish to delid?
Reply 6 of 27, by RandomStranger
I share the same opinion of momaka. If you plans are for the XP era, that is you don't plan to go past 2009-2011 games, an Ivy Bridge I3 is perfectly fine. There are some models with 35W TDP if you are concerned about overheating.
Reply 7 of 27, by DudeFace
vermillion wrote on 2024-10-22, 10:39:
Hi , I have a few 1155 motherboards all Gigabyte GA-H61M-S2PV (rev 2.1) and i want to build a xp system. which Cpu would be best […]
i've got the same motherboard, i got it as a barebones bundle from my local computer shop years ago mine came with an i3-3240 dual core, if you're running 32bit xp probably not much point going for a 4 core, even if you're running 64 bit xp a dual core i3 wil be enough, those 2nd/3rd gen i3's are pretty good, also those look like Cex prices, i3's can be had for pennies, just bear in mind they keep all their cpus kicking around in a box, unless you get one from a display case. if you're worried about thermal compound just dont get a"K" cpu.
Reply 8 of 27, by vermillion
DudeFace wrote on 2024-10-22, 13:05:
I was only considering the I5's and I7's due to there cache, but unsure what diference it would make in this situation.
Reply 9 of 27, by Munx
I'll also hop on the "there's no need for more than 2 cores for XP" train. Even the low-end Sandy-Bridge Pentiums will handle any game from that time very easily.
My builds!
The Underdog - The budget K6
Reply 10 of 27, by G-X
Unless your cpu is showing temps that are way off i would advise against delidding. Who knows you could be risking your cpu for a 1 or 2 degree benefit ... totally not worth it.
As stated by others an i5 isn't going to be any better. Get an an i3 with low TDP if temps are of great concern or get a decent cooler and just get the fastest i3 possible, plop it in and enjoy. (i bought one for a fiver ... these are dirt cheap)
Philscomputerlab also hase some interesting videos with i3's.
i3 3250 seems like a good choice .. highest clocked i3 (3.5ghz) with a 55w TDP (instead of some 65w)
If really needed you could get an 3250T but these are clocked 500mhz slower but have a luch lower 35w TDP.
Also TDP is not a straight comparison to temps ... sure the T models will be cooler but it won't be half as much. I'd have to look it up how this rating actually stacks up in the real world.
Here you have a list
https://www.cpu-world.com/Sockets/Socke ... 1155).html
Edit: honestly just get whatever i3 you can find for a fiver and plop it in and enjoy. I've made the same mistake countless times of overthinking stuff and spending way too much for minimal gains in performance. Besides these cpu's run circles around C2duo cpu's and even those are more than enough for XP.
Reply 11 of 27, by vermillion
Pushed the button on an I3-2130 3.4GHz 65watt TDP. Thinking the soldered IHS is a plus.
Reply 12 of 27, by DudeFace
vermillion wrote on 2024-10-22, 13:10:
probably not much, a lot of xp era cpus had cache that was 512kb or less even into the dual core era with 775/AM2 sockets, on xp anything more than 3mb wont really be needed.
Reply 13 of 27, by SPBHM
large cache is not needed but still improves perf, I think the i3 is plenty fast for XP games, but you would get some higher 3dmark scores or whatever (even if only using 1 core) with an i5 or i7 due to clock and larger cache.
in saying that even a Pentium G620 will likely perform on the same league as an e8600 while using probably close to half the power.
so, very fast for xp
Reply 14 of 27, by momaka
vermillion wrote on 2024-10-22, 12:59:
Certainly!
Both of my 2.8 GHz Pentium 4 Prescott HT systems are still running trouble-free, despite being rather hot chips. Actually, the thermal compound between the IHS and the CPU cooler is probably long-overdue for a change on both... though I'm not 100% certain, as these are in Dell systems with no temperature probes, so I have no idea how hot the CPU is running. All I know is, both of these systems still run crash-free under 100% load even in extremely hot weather (my computer room is mostly sitting at 30C / 86F in the summer, which I think anyone here will agree is quite hot.) The motherboard around the CPU doesn't seem to get excessively hot (for a Pentium 4 Prescott CPU anyways), so it looks like the original pre-applied Dell TC from 2005 is still doing the job.
It might in some (very few) games... but for most, high core clock is the king above all.
G-X wrote on 2024-10-22, 13:26:
Indeed.
Soldered IHS CPUs will almost always yield lower running temperatures compared to non-soldered IHS CPUs.
Then there's another consideration: what is TDP actually defined as.
For GPUs (particularly more legacy GPUs), this is typically the highest power the chip will dissipate in terms of heat under 100% load... hence what is meant by thermal design power (TDP).
But for CPUs, it's a bit different, especially between Intel vs. AMD.
For most Athlon 64 CPUs, for example (mainly s754, 939, and most of AM2), TDP is generally the highest power you can expect a CPU to output in terms of heat under 100% load (with stock clocks and voltages). With Intel, that's not quite so. A "67W" TDP Core 2 Duo can often output around 100 Watts of heat when running under 100% load. Likewise, a Core 2 Quad can jump in the 140-150W range, despite being labeled as "95W" TDP. When it comes to even newer Intel chips, it seems that the TDP vs. actual power consumption constraints can vary even more. So indeed "95W" from one CPU generation may not actually be the same as "95W" TDP from the next or previous generation.
That said, the TDP rating can still paint an overall good picture about the actual power consumption / heat output of a CPU, so it's always worth considering.
Reply 15 of 27, by ElectroSoldier
vermillion wrote on 2024-10-22, 13:34:
I bought a similar setup from a friend of mine (no reason other than he was looking to sell).
It was bought as a "gaming" PC back in its day but it had an i3-2120 CPU...
Anyway.
But I set it up running XP to test it all out, it has a GT 210 video card. It seemed to run Dawn of War, Res Evil 4 and Smert shpionam after I changed up to a GTX 285
Reply 16 of 27, by DudeFace
ElectroSoldier wrote on 2024-10-22, 14:12:
I bought a similar setup from a friend of mine (no reason other than he was looking to sell). It was bought as a "gaming" PC bac […]
Anyway.
good choice on the gpu, years back i had the same motherboard as OP with an i3-3240, and i bought a gpu from my local computer shop because it was the cheapest they had and i thought it was better than the onboard graphics, that was a Gt 220, i still have it and recently found out for its time it was pretty piss poor, performance is not much more than a 7950gt from 2006, and its on par with an 8600GTS, tho mine probably wasnt as it was the gimped version with ddr2 memory 🤣, a 210 is probably much less powerful.
Reply 17 of 27, by auron
just saying that UT3, a DX9 game from 2007 benefits tremendously from HT even on quadcores. this video makes that exact point: https://www.youtube.com/watch?v=ZXfPPdLEa2s&t=139s
this is just one game of course, but the engine was popular in the day, so presumably there are more late demanding games that run on XP and benefit from an i7.
Reply 18 of 27, by havli
As others said - i3-3250 is perfect CPU for pretty much any XP game. But Ivy Bridge i5 is even better. You can geth both for peanuts (around here at least). I would avoid Core i7 as they tend to be much more expensive and provides only HT, which is useless for XP (with 4 real cores).
Don't bother with low-power variants. They perform worse and power consumption is non-issue even with the regular i3 and i5. You can expect about 25W power consumption on the i3 and 40W on the i5 IB (that is under full load.... which you wil never reach on the i5 when gaming). Also soldered (SB) or regular TIM (IB) doesn't matter when running at default clock. Yes - SB might run 5-10°C lower, but who cares, right? We are talking temperatures in range 40-50°C.
Reply 19 of 27, by momaka
Hehe, that's literally going "from rags to riches" 🤣 . The GT 210 is pretty close to a meme card... though I shouldn't laugh given how many PCs I set up and tested with Radeon HD2400 Pro/XT - another pretty meme-y card. At least the HD2400 is very low power - 19W TDP vs. the 34W of the GT 210.
Speaking of video cards, I do wonder what the O/P is going for, if system reliability is such an important factor.
Most high-end video cards run hot and aren't exactly reliable in the long run, IME. Mid-range stuff can swing either way, depending on the cooler choice that each (3rd party) manufacturer went with. And the low-range cards always tend to be the longest-lasting... partly due to low TDP, and partly due to just having smaller, simpler cores (so not as much to go wrong with, BGA-wise).
I usually aim for the low and mid-range cards, as the lower TDP of these also means less strain on the PSU and less heat to deal with inside the PC case. Some of my common picks are (in no particular order) GeForce 9600 GT, HD4650/4670, HD7570, HD3870, GT430 / Quadro k600, Quadro 2000 / GTS450, GTX 750/TI.
The HD4650/70, HD7570, and Quadro k600 might conk out and/or drag their butts quite a bit behind in high resolutions, particularly due to lower ROP count. If you want to run games at high[er] resolutions, then the ROP count is probably the most important thing, followed by memory bandwidth.
havli wrote on 2024-10-22, 17:58:
Agreed.
However, that 40-50C can easily become 50-60C with elevated room temperatures, if the fan profile on the mobo isn't setup to deal properly with elevated room temperatures.
