First post, by AlessandroB
This SBC is connected inside an Amiga2000 and works perfectly. Since it is rarely used, I would like to turn it on only when I need it because as soon as I turn on the Amiga 2000 the ISA connectors (which are like a Backplain) receive power and turn on the SBC. From the manual it seems possible but I have not been able to interpret it.. in your opinion what should I jumper on the board? Thanks
Reply 1 of 4, by Ryccardo
You probably can't, at least inside the Amiga…
What the board can do, is to control an ATX power supply (example: AT backplane, ATX power supply with AT adapter, you connect a regular power button + the green and purple wires to the right pins of the JP3 connector, and you get it to work like a regular ATX computer) - but it probably can't turn off on its own if something else (the Amiga, or in the above example if you connect the green wire to a classic "AT" power switch as normally done) is giving it power…
Reply 2 of 4, by eisapc
For SBCs used with ATX power supplies usually an additional connection from the Backplane to the SBC is needed.
ISA and PCI Slots do not carry the 5V standby power line needed to start the system.
The connections differ between manufactures.
While Advantech uses a 3 wire connections others like Bluechip use 5 pin connections.
Be careful messing around with these connections.
Fried an Advantech SBC last nicht while trying to connect it to a Bluechip backplane via wrongly soldered adapter.
Reply 3 of 4, by AlessandroB
Honestly this SBC is connected only to the isa slot without any other connections and it works perfectly. Except that I would like to turn it off, but I'm afraid that it can't be done
Reply 4 of 4, by auron
then put power management in bios to max saving. and a plug power meter will tell you if it helps.
