First post, by naujoks
I have a CT2800 SB16 (based on Vibra chipset), that gets recognised by the system ok and outpus sampled sounds but stays completely silent for music.
The jumpers on it should all be in the correct position. Physically the card is in good shape, I have not discovered obviously busted parts or dodgy soldering.
The two voltage regulators on the card are outputting the correct voltages.
What could be the problem and what I can measure to find out where the problem is?
