First post, by foxbat
I have several Mach64 cards on PCI in various versions of memmory chips there. Based on your experience with Mach64 cards, which are the best versions of drivers for:
1. Win 3.x
2. Win95
3. Win98(SE)
Should I just use the latest available? If yes then what are final versions that I should look for each OS?
Reply 1 of 1, by marxveix
foxbat wrote on 2024-10-30, 19:57:
I have several Mach64 cards on PCI in various versions of memmory chips there. Based on your experience with Mach64 cards, which […]
1. Win 3.x
2. Win95
3. Win98(SE)
Mach64 CT/264CT - Cost-reduced Mach64 with integrated RAMDAC and clock chip (up to 2 MiB DRAM)
Win9x ATi MACXW4 5.39 drivers would be the latest, i know only this wayback machine download link for it (this download does not work). I would try from newest to older.From 5.38.x MACXW4 driver 5.38.2 / 5.38.3 / 5.38.6 to lower 5.37.x and so on, sad that we do not have ATi 5.39 driver available at the moment. 5391b10e.zip is the file name. At least those driver are Mach64 (Rage2) compatible, as should be 5.39 (5391b10e.zip).
3D TURBO ACE,3D MULTI EYE, 3D POP (Direct 6.0지원) Version 5391b10e (00/02/14)
https://web.archive.org/web/20000422165828/ht … rea/support.htm
Driver date 14 februrary 2000 - 5391b10e.zip(6,388KB)
https://web.archive.org/web/20000613150221/ht … orea/driver.htm
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
