First post, by jedikwon
Hello. I got this Voodoo 2 with bent pins. I was able to straight them and re-connect a broken pin.
The attachment voodoo2.JPG is no longer available
I've never done this before so it was a really difficult job to me but somehow I made it working again. Hooray!
Now my question is, how to protect the pins from now on. I did separate the pins so that they can't touch each other but they are so close right now.
A little shock can cause a short and may not work properly, maybe even gets disconnected again.
So should I just cover the whole area I marked in the picture with UV solder mask? Is the material shrink or expand as they are being cured? If so, it will definitely make pins touch each other.
I don't know, should I just leave them as it is right now? At least it is working. What do you guys suggest?
Reply 1 of 9, by Tiido
You should use a much thinner wire, perhaps just a single strand from the one currently used. It will be much less mechanically fragile then, and that UV solder mask can be enough of a glue to hold stuff stably in place even during more rough handling. Right now if anything is going to push on the fat wire, it'll break off on the chip end, instead of giving in a little and deforming itself. It will also help to solder that strand on the trace itself rather than the via further away, then there's less material to get disturbed although it can be another difficult challenge to overcome.
As is I would probably use epoxy on the chip end, after everything is properly soldered down. These chips get pretty hot so things like hotglue won't be very stable.
Reply 2 of 9, by Cursed Derp
Dammm that's a crazy repair! Congratulations
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 3 of 9, by jedikwon
Tiido wrote on 2024-11-02, 17:52:
Thank you for your suggestion. But honestly, putting that solder ball on the chip was a pure luck. I tried many times to put it on and finally was able to make it. So oh no, I do not want to touch it again.
I could've used a thinner, one strand of the wires but again, I tried it and failed. This was one time I was able to make it work.
So I guess you suggest epoxy over UV solder mask? I don't even have epoxy and don't know how it works. Okay, I gotta study that thing.
Reply 4 of 9, by jedikwon
Cursed Derp wrote on 2024-11-02, 17:52:
Thank you so much. I still cannot believe it actually works!
People on Youtube are really awesome to share their repair videos, it helped me a lot.
Reply 5 of 9, by Tiido
You can try to see how well the UV cure solder mask holds on some other thing, i.e put a wire in place and see how it'll hold to some handling. But you will still have to be very careful with handling, I have doubts it'll be strong enough to resist nudges to that wire. Perhaps you can put it into a machine where it will be undisturbed, along with a big note along the lines of "to future me : be super careful" 🤣
Reply 6 of 9, by S95Sedan
Not what you want to hear but get rid of this, the wire used is way too heavy and the joint will break off eventually again.
Putting conformal coating on this will make a future repair or fix even harder.
Reply 7 of 9, by bloodem
You really need good equipment for this type of repair, especially a good digital microscope and last but not least... a lot of experience.
Having said that, congratulations for a first successful (albeit ugly and fragile) attempt. 😀
I've just repaired a damaged Voodoo 2 a few days ago (it had quite a few missing components + many bent pins, a few broken ones and missing/detached solder pads). This is what I ended up with:
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 8 of 9, by jedikwon
Oh.. okay. Yeah, I know that was my first attempt and looks ugly and fragile.
So the general consensus here tells me that putting UV thingy is a bad idea and try a thinner wire to repair as shown in pictures.
Well, okay, I will try it this weekend. Wish me luck guys. I hope I am not gonna ruin the card.
Reply 9 of 9, by Postman5
If you start soldering thin wires, it's hard to stop 😀
