First post, by xtreger
I've installed nusb drivers 3.6 for Win98SE. If I only install those, my Sandisk Cruzer Blade doesn't even get detected. If on top of that I install the ICH7 Intel 82801 USB2 driver, then the pendrive gets detected, but only when I go to device manager and click refresh.
Similarly if I only install the intel drivers, then again the pendrive isn't detected. Basically, both nusb and Intel drivers are needed. The trouble is, even after that if I insert the pendrive, it doesn't get autodetected and automounted as a partition. This only happens after the device manager manual process.
Any idea on how to fix this? The motherboard is GA-G41MT-ES2L.
Reply 1 of 1, by Horun
Curious what size pendrive is it ? This is def a Win98SE issue. Nice seeing a late model soc 775 micro board with a floppy connection 😀
