First post, by RetroPCCupboard
I bought this on ebay recently.
The attachment 20241105_110350.jpg is no longer available
What caught my eye was that it was an AT board with built in Ps/2 socket and supports EDO RAM and Pentium MMX.
The seller posted a photo showing that they had it running a Pentium MMX (though at an odd frequency):
The attachment SmartSelect_20241105_111546_eBay.jpg is no longer available
The question though, is how did they set the voltages for the CPU? I can see no jumpers for it on the board. Presumably this is too early a board to support jumperless voltage setting?
I may be blind, but I can't see any identifying markings that might help me find a manual for it...
Reply 1 of 15, by zuldan
Check out those red jumpers in the VRM socket next to the CPU. Have a look at this video, Necroware gives you a good understanding on how they work. You could also build one of his VRMs.
https://www.youtube.com/watch?v=CMiGVQbMC5U
Reply 2 of 15, by PC Hoarder Patrol
RetroPCCupboard wrote on 2024-11-05, 11:20:
I bought this on ebay recently. […]
https://theretroweb.com/motherboards/s/pcchips-m520
Reply 3 of 15, by RetroPCCupboard
PC Hoarder Patrol wrote on 2024-11-05, 11:31:
Thanks! How did you identify it as this board?
This note on that website is a little scary:
Inadequate Power Delivery
This motherboard may have insufficient power delivery, which can lead to unstable or unsafe operation. In extreme cases, this may result in hardware damage, spontaneous combustion, or other electrical failures. Users should exercise caution and consider upgrading the motherboard power supply or other components to ensure safe and stable operation.
Reply 4 of 15, by RetroPCCupboard
zuldan wrote on 2024-11-05, 11:25:
Fascinating. So it would seem that this motherboard doesn't support Pentium MMX and the seller most likely ran their MMX CPU at 3.3v instead of 2.8v. Obviously I don't want to kill my CPU, so won't be doing that! I will drop in a standard Pentium just to check the motherboard works OK. Then I guess I will have a project on my hands to make this work with an MMX CPU. A project for a later day though, as that sounds like a lot of work for an electronics novice like myself.
Reply 5 of 15, by PC Hoarder Patrol
RetroPCCupboard wrote on 2024-11-05, 11:37:
Thanks! How did you identify it as this board? […]
An easy find using The Retro Web search page advanced options (socket, expansion slots, chipset etc.) - https://theretroweb.com/motherboards/
Loads on Vogons using the M520 successfully so don't worry too much about the power delivery note.
Reply 6 of 15, by RetroPCCupboard
By the way, my hope for this platform is to make a Pentium MMX as slow as possible for compatability with older games. Hopefully the rather old chipset on this board will make it slower than can be achieved on a platform that officially supports the CPU. Hopefully it will be possible to be as slow as a fast 286 when combined with EDO ram on slow timings, an ISA video card and disabling caches and performance features of the MMX CPU. But, in the meantime, I do have a slightly more modern AT board that supports the MMX.
Reply 7 of 15, by RetroPCCupboard
PC Hoarder Patrol wrote on 2024-11-05, 12:50:
Ah. Handy. I didn't know you can search like that
Reply 8 of 15, by zyga64
It will be slower (although not very much) than the average VX boards because it doesn't have any L2 cache 😀
(until you'll find cache stick for it)
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 9 of 15, by dionb
RetroPCCupboard wrote on 2024-11-05, 12:14:
The BIOS supports it, but the board only has an onboard VRM for 3.3V, so you need to add the VRM to be in spec.
Add to that that the 5V-3.3V VRM is pretty notoriously bad/under-specced and it's not the best of boards to push your luck with.
If you really want to go with this classic piece of PC Chips crapware (which in itself is a good challenge), I'd follow suggestions for building your own VRM module for it, and then power that module directly from PSU and so actually reducing the load on the poor onboard components.
Not likely, chances are that the MOSFET under the CPU socket will burn out at some point, but that will kill the motherboard, not the CPU. For that reason, old motherboards tend to be rarer than old CPUs to go in them.
Necroware's VRM is here:
https://github.com/necroware/s7-vrm
Note that it requires some SMD soldering (not trivial for a complete beginner) and draws power from the motherboard, so not perfect - but at least it draws 5V not 3.3V, so won't affect the underdimensioned VRM adversely.
RetroPCCupboard wrote on 2024-11-05, 12:54:
i430VX isn't a speed demon, but it's only a few percentage points behind the i430TX, which is Intel's fastest chipset for the MMX and clock-for-clock one of the fastest of the So7 chipsets overall. So choosing i430VX won't handicap it much. Not having L2 cache (like on this board...) will however handicap it significantly. Turning off L1 cache as well will get you seriously slow though.
If you wanted to choose the slowest chipsets for Pentium MMX, go for SiS 5511 with 6202 UMA graphics, or SiS5596 (same compontents integrated into the same chip). Not only does the integrated graphics eat half your memory bandwidth, you can also run on a single 32b SIMM, further halving the performance.
Reply 10 of 15, by RetroPCCupboard
dionb wrote on 2024-11-05, 14:32:
Well, to look at it another way, if you are going to experiment on something when you don't know what you are doing, then choose the crappiest thing you have to practice on 😀
If you really want to go with this classic piece of PC Chips crapware (which in itself is a good challenge), I'd follow suggesti […]
Thanks for the link. It is an interesting project. I didn't buy this board with the intention of it becoming a big project, so will have to park it for now. But certainly will consider doing this VRM upgrade later so I can use an MMX chip in it. It's always good to have backup options just in case the primary board fails.
I wonder how much making such a VRM board would cost (including all the components). Any idea?
Yeah, my other board is 430 TX. I haven't been able to find any comparisons between the TX and VX in terms of performance. But I am aware that the VX is a budget chipset and not considered to be as good. It will be interesting to play with. Thanks for the info on the SIS chipsets. Looks like there's none for sale on ebay locally currently, but will look out for it.
Reply 11 of 15, by Joseph_Joestar
RetroPCCupboard wrote on 2024-11-05, 15:44:
There's a feature set comparison between TX and VX in this Anandtech article.
No benchmarks, but it should still give you some useful info.
My retro stuff
Reply 12 of 15, by RetroPCCupboard
Joseph_Joestar wrote on 2024-11-05, 16:12:
Many thanks for the link.
Actually, I was mistaken, there are some SIS 551x socket 7 boards locally. However, they seem similar to the one that I just bought in that they don't seem to allow dual voltage CPUs and would need modification.
Reply 13 of 15, by dionb
Here's a comparison I did a while back:
http://dionb.eu/chipset1.html
Compare the P-INT and P-FLOAT scores. Pretty much equal with EDO; TX is 7% or so faster in terms of memory performance (i.e. less difference in real-world applications). Also note that the difference between boards with same chipset can be bigger than the difference between chipsets.
It's not actually, it was Intel's flagship desktop chipset for about nine months, released in parallel to the i430HX, with the HX designed more for servers and workstations. The HX supported more RAM but the VX was faster paired with SDRAM. The only reason it looks mediocre in retrospect is that it was completely outclassed by its successor and by later competitors (ALi Aladdin IV in particular). Right now there's absolutely no reason to go for VX if you have access to TX, but end 1996, beginning 1997 it was the fastest option out there. There's a reason so many people bought one.
RetroPCCupboard wrote on 2024-11-05, 16:36:
That's just par for the course in late 1996. Look for the 5596 for fully integrated stuff on a board with built-in VRM. They were later (end 1997, early 1998) and squarely positioned at the low end, so don't expect fancy boards. Then again, you now have a PC Chips board with warning about its linear 5V->3.3V VRM, so it's not likely to be any worse than that 😉
Reply 14 of 15, by BitWrangler
Yeah I've messed with some VX boards that were no better than FXes, and others that bested the mediocre TXs. Probably their "niche" at the moment is the lowest price ATX board, there weren't many, but everyone will be looking for TX or MVP3 or Ali. RAM can be a pain in the butt with them though, two 32MB is the low stress complement.
Reply 15 of 15, by RetroPCCupboard
dionb wrote on 2024-11-05, 18:02:
Hmm. That is interesting information. Must have taken you a while to compile that!
OK. I saw an article on DOSDAYS website where the wording made me think what I did. But I am happy to be corrected.
Socket 7 boards seem to have gone up in price since I last bought one (3 years ago maybe). Super-socket 7 though. Wow. Crazy pricing on those. Even several years ago.
