First post, by Einherje
Hi all
I run a CT2230 SOUNDBLASTER 16 and an IBM 88G4919 4 speed SCSI CD-ROM drive. I'm pretty happy with my setup but I can't get Red Book audio to work in games (or in general). My CD-ROM drive is connected to the SB16 by audio cable. Do I need a specific driver or something? When I try to play an audio CD from qcd.exe the program freezes. When I play a game requiring Red Book audio, like the CD-ROM version of Loom, there's just no sound.
My config.sys:
[MENU]
MENUITEM=CDROM, DOS with SCSI CD-ROM
MENUITEM=VCDROM, DOS with virtual CD-ROM
MENUDEFAULT=CDROM,10
[COMMON]
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF /Q
DEVICE=C:\DOS\EMM386.EXE RAM HIGHSCAN
DOS=HIGH,UMB
BUFFERS=11,0
FILES=60
FCBS=1,0
STACKS=0,0
BREAK=ON
LASTDRIVE=E
DEVICEHIGH=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5
DEVICEHIGH=C:\SB16\DRV\CSP.SYS /UNIT=0 /BLASTER=A:220
DEVICEHIGH=C:\SB16\DRV\CTMMSYS.SYS
DEVICEHIGH=C:\DOS\SETVER.EXE
DEVICEHIGH=C:\DOS\DISPLAY.SYS CON=(EGA,,1)
COUNTRY=045,,C:\DOS\COUNTRY.SYS
[CDROM]
DEVICEHIGH=C:\SCSI\ASPI8DOS.SYS
DEVICEHIGH=C:\SCSI\ASPICD.SYS /D:MSCD001
[VCDROM]
REM No additional device drivers needed but option seems not to work if section is empty
autoexec.bat:
@ECHO OFF
PROMPT $P$G
PATH C:\DOS;C:\SB16
SET TEMP=C:\DOS
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH:1 MAP:E
LH C:\SB16\DIAGNOSE /S
LH C:\SB16\SB16SET /Q
LH C:\DOS\CTMOUSE.EXE
MODE CON CODEPAGE PREPARE=((850) C:\DOS\EGA.CPI)
MODE CON CODEPAGE SELECT=850
KEYB DK,,C:\DOS\KEYBOARD.SYS
GOTO %CONFIG%
:CDROM
REM LH C:\SHSUCD\SHSUCDX.COM /D:MSCD001 /L:E
LH C:\DOS\MSCDEX.EXE /D:MSCD001 /L:E
LH C:\DOS\SMARTDRV.EXE D 4096
GOTO END
:VCDROM
REM Virtual CD-ROM mode
LH C:\SHSUCD\SHSUCDHD.EXE
LH C:\SHSUCD\SHSUCDX.COM /D:SHSU-CDH /L:E
GOTO END
:END
My mixer settings (sb16set.exe):
When I try to play an audio CD by means of qcd.exe, the program detects the audio tracks, but when I press play or change track, the program freezes:
The back of my CD-ROM drive (with audio cable disconnected):
Pictures of my rig because I love it to bits:
Reply 1 of 10, by thp
Things to try:
- Use a different CD-ROM driver
- Use MSCDEX instead of SHSUCDX
- Make sure the mixer has CD-ROM unmuted
Reply 2 of 10, by Einherje
Thanks. Just tried MSCDEX.EXE with same results (autoexec.bat changed accordingly in original post). I think CD-ROM is unmuted but I'm not entirely sure. How does my sb16set.exe look?
Reply 3 of 10, by Joseph_Joestar
Einherje wrote on 2024-11-05, 11:46:
It looks like your CD-ROM drive has GLGR for the pinout, while Sound Blaster cards usually use RGGL on their primary connector.
Make sure that the cable is correct, and that the pinouts on the CD-ROM drive and the sound card match.
My retro stuff
Reply 4 of 10, by Einherje
Sounds plausible, but wouldn't I at least get sound from the right audio channel to my left speaker then?
Reply 5 of 10, by Joseph_Joestar
Einherje wrote on 2024-11-05, 12:00:
To eliminate the cable as a potential cause of the issue, power down the computer and disconnect it entirely.
Then, turn the system back on and try playing CD audio again. You won't get any sound while the cable is disconnected of course, but if the system doesn't freeze, then there's a good chance that the cable is either defective or incompatible.
My retro stuff
Reply 6 of 10, by Einherje
I rewired the cable and still get the same issue. Might be the cable itself, although it looks to be in good shape.
Reply 7 of 10, by thp
You could also try booting a live Linux CD (that loads completely into RAM) or a live Linux USB and see if that can play CD-Audio (make sure it uses analog playback and not digital extraction, which would work without the audio cable). Then, also cross-check with a different CD-ROM drive to exclude your current one as a source of the issue.
Also, since your CD-ROM drive still has a headphone jack and volume wheel at the front, connect some headphones to it and make sure the volume is set to something audible. This way, you can check if if's possibly the connector at the back of the CD-ROM (and it's otherwise playing back and decoding CDDA properly) or if it doesn't even get to the point where it's playing back the audio.
Reply 8 of 10, by weedeewee
Have you tried playing an audio cd with headphones connected directly to the front of the cdromdrive ?
Do not ask Why !
Reply 9 of 10, by Einherje
@weedeewee
Good idea! I'll give it a go tonight.
Reply 10 of 10, by Einherje
Not playing audio from headphone jack even when disconnected from soundcard. Guess I'm looking at a new CD-ROM drive.
Thanks for your inputs all.
