itzCrassio wrote on 2024-11-05, 16:47:I have an old PC which I inserted a sound card into. That sound card has a game port, and was happy when it was working with the […]
I have an old PC which I inserted a sound card into. That sound card has a game port, and was happy when it was working with the sound card's driver in MS-DOS.
However, it seems like that anything other than DOS just dosen't want to detect my joystick.
Joystick: Gravis Blackhawk (analog)
Specs:
- AMD Athlon 64 3000+
- Soltek SL-K8AV2-RL
- CMI8738 sound card
- NVIDIA GeForce2 MX400
I tried the following options:
1. Installing the sound card's drivers. Still dosen't work. Windows XP still dosen't recognize a joystick. Recognizes a game port driver though.
2. Reinstalling Windows XP. Shows game port, but apparently the ID of it is from an internal VIA chip, the motherboard dosen't have a game port.
3. Tried adding joystick manually. There was no analog version of the Gravis Blackhawk joystick there.
4. Installing Gravis Xperience. Said that there were no joysticks connected.
I'm all out of options.
i was gonna say its probably a driver issue, there are many different drivers for these cards, the one i was previously using i had about six different drivers that installed different things, one installed windows/gameport, another installed windows/dos, another installed windows/dos/gameport, another installed the same but also the audio rack in control panel, a couple of the other drivers just didnt work
last time i tried installing the card i forgot which drivers worked got fed up with it, and switched to a sound blaster live, funnily enough i've just picked up another cmedia 8738 card and im about to have another go with it, mine came with a driver cd but ill be using the latest drivers from cmedia i found online, this is the latest one so try this if you haven't already. "C-Media CMI8738-MX PCI Audio Driver 8.17.34 for XP" i no longer have a gameport controller so cant help in that regard. if the gameport is actually showing up in control panel you may need an xp driver for your controller.
forgot to say that driver should cover the LX not sure about the SX.
