First post, by psaez
Hi, i hace a multi boot systen with aopen ax34 and pentium 3 1ghz.
Under windows 95 it works perfectly. But under windows 98 SE, I got this problem:
Sound was not working, so I openned device manager and I saw an error on my audio device called "creative sound blaster pci128 legacy mode". When openning it I got this message of the problem it had:
This device cannot find free Direct Memory Access (DMA) resources to use (Code 12.)
The only way I found to make sound work was to disable a device. In this case I disabled "Creative gameport joystick". Then, the sound started working and the error dissapeared.
But something is still broken because sometimes I got blue screens and game frozens, and this doesnt happens with windows 95. Also dont happen on my othe retro computer with windows 98, but thar computer haves a tualatin and a different motherboard.
Any ideas?
Reply 1 of 31, by psaez
Anyone?
Reply 2 of 31, by psaez
still with the issue
Reply 3 of 31, by Babasha
psaez wrote on 2024-11-10, 12:52:
Hi, i hace a multi boot systen with appen ax34 and pentium 3 1ghz. […]
Any ideas?
Turn of automatic resource management for Creative legacy audio and set up resources manually.
Need help? Begin with photo and model of your hardware 😉
Reply 4 of 31, by psaez
Babasha wrote on 2024-12-08, 14:14:
Any ideas?
Can you give me a little help with doing that?
Reply 5 of 31, by Babasha
psaez wrote on 2024-12-08, 15:28:
Any ideas?
With screenshots from you.
Reply 6 of 31, by rasz_pl
This is most likely caused by broken bios ACPI tables, those are responsible for resources. Win95 probably ignores those 😀
You can try updating bios, but it might be unsolvable without manually fixing resource allocation and editing bios - hardcore.
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 7 of 31, by psaez
rasz_pl wrote on 2024-12-08, 16:12:
I see that bios is from 2001 and there is a 2004 version of the bios, you mean that if I update it, the problem will be solved?
Will be necessary to reinstall W98 ?
Reply 8 of 31, by Dmetsys
Seeing that you are using a VIA Apollo Pro 133A motherboard, did you install the VIA Service Pack 4.43 prior to installing the sound card drivers?
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 9 of 31, by Horun
psaez wrote on 2024-12-08, 19:32:
No you should not have to reinstall W98.
Reply 10 of 31, by psaez
Dmetsys wrote on 2024-12-08, 20:17:
I installed this: via-4in1-443v-63160adabfe43125550176
from here: https://theretroweb.com/motherboards/s/aopen-ax34#driver
is that the service pack you are talking of?
Reply 11 of 31, by psaez
Horun wrote on 2024-12-08, 21:16:
I'll try when I go to that place. Will it be necessary to uninstall and reinstall drivers? or everything should start working fine without doing nothing?
Reply 12 of 31, by Horun
psaez wrote on 2024-12-08, 21:42:
No you should not have to reinstall drivers but W98 may do a few "found new hardware" thingy's...
Reply 13 of 31, by Dmetsys
psaez wrote on 2024-12-08, 21:41:
I installed this: via-4in1-443v-63160adabfe43125550176 […]
Yes. That should be installed first prior to installing drivers for graphics cards and sound cards.
Reply 14 of 31, by psaez
Dmetsys wrote on 2024-12-08, 23:18:
Hey guys, I finally updated BIOs to last version, 2004 version, and the issue persisted. I even formatted and reinstalled windows 98 SE with the last bios, and the problem persisted.
Any idea how to solve this?
Reply 15 of 31, by OVERK|LL
psaez wrote on 2025-02-02, 21:36:
Hey guys, I finally updated BIOs to last version, 2004 version, and the issue persisted. I even formatted and reinstalled window […]
Do you have Plug and Play on or off in the BIOS?
DD: Mac Pro 5,1 - X5690, 64GB, RX 580 - OCLP w/Sequoia
Projects:
- Hewitt-Rand 8088 - 640KB, 20MB, Hercules mono
- IBM PS/1 2133 w/Thermalwrong solder mod - ODP 486DX4-100, 32MB
- PCPartner VIB806DS w/233MMX, 128MB, G450
- Jetway J-TX98B w/P75, 256MB
Reply 16 of 31, by psaez
OVERK|LL wrote on 2025-02-02, 21:41:
I'm not there now, I go to that place once each 2 weeks. If I can remember correctly, yes, it was ON in the BIOS. How can that affect? what should I try when I go there?
Reply 17 of 31, by OVERK|LL
psaez wrote on 2025-02-03, 10:11:
When it's on, Windows is expected to manage resources and sometimes it doesn't do a very good job. Turning it off has the BIOS manage it, which can often fix errors such as the one you are experiencing.
Projects:
Reply 18 of 31, by psaez
OVERK|LL wrote on 2025-02-03, 13:22:
that machine has a multiboot with win3.11, win95, win98se and winxp
disabling it seems to be a bad idea
Reply 19 of 31, by OVERK|LL
psaez wrote on 2025-02-04, 15:06:
Given that list of OS's, it sounds like it's probably a good idea to turn it off. You can always turn it back on, but 3.11 doesn't support it.
Projects:
