Small Stargunner problem
First post, by IceAIM
For some reason if I make my CPU cycles higher than 10,000, I can't use my gamepad properly. It simpy won't calibrate right and the curser would just always try to move straight down.
I'd like to get the cpu cycles up a little more so I can run the game in full detail. Right now I am running it with details maxed out, but the shrapnell detail is reduced because it seems that it bogs the game down.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
try setting the cycles before starting the game (or calibrating it)
joystick timing is time based. so changing the cycles will change the time
did you use the CVS or 0.63 ?
Water flows down the stream
