First post, by Ujeen
Hi dear VOGONS tenants. I hope everyone is doing well. I've been reading a forum for couple weeks only (even went almost through the whole "Test and troubleshoot PC@LIVE motherboards" topic 😀 quite useful but I didn't find answers to my questions there). Finally decided to ask couple questions here if nobody minds.
I suddenly decided to assemble my first machine I bought after got my first job in Moscow back in 2002. I didn't find that exact motherboard, but I found something close enough: eMachine AU31 (this one https://theretroweb.com/motherboards/s/fic-au31-l) from Goodwill online auction for something around $20 (no guarantees etc, which is usual thing). It came with Athlon XP +2100. I aquired an old 300W powerman PSU from ebay. WHen I got PSU I measured all voltages, made sure it works ok. Then I double checke the motherboard itself: I made sure all caps look good, there is no visually busted mosfets and transistors. I changed the CMOS battery (the old one was done). The motherboard and CPU overall looked clean and shiny. No scratches, no bent pins...Then I connected the PSU and ensured the standby 5 volts is there. I didn't have CPU heatsink but I thought if I switch it on briefly it will be ok. So I did and immediately smelled hot burning electronic. I turned all off. Sniffed everywhere 😀 and realized the smell is coming off the processor. And yes it had a brawn-ish spot on it's bottom. I assumed this was my fault to run it without heatsink on it. I ordered a new one from Croatia and while waiting I started exploring this motherboard.
- mother board jumper is set to the 100/133 freq position
- I bought a chip oscilloscope and probed clocks (first with just battery inserted, then with PSU on): those looks good, the signal is clean , no noise in it.
- measured all three VRM phases which looked like fine: both high and low sides seems to have proper drain voltages
- I de-soldered VRM's caps and measured their ESP which confirmed they are fine and capacity is fine but anyway I soldered all new caps in (same capacitance and voltage of course)
- I measured PWM's outputs. Also looked correct and even with the burnt CPU installed it shows PWOK and all three PWMs look fine.
- I bought PC analyzer from ebay and of course it showed no post codes with the burnt CPU installed. However the reset signal was lifted as it should be and it showed all voltages nominal.
Then I got my "new" CPU along with a heatsink and fan. I installed it and turn this all on and I even saw couple post codes and then I smelled it ... again. Turned everything off, removed heatsink, pulled CPU and viola same brown-sh mark on the same exact place.
Ok now having two fried CPUs:
- I checked VCC_CORE on CPU socket: shows 1.67 volts
- I measured voltages on all pins and realized I may have three places with 2.5 volts but those appeared to be expected according to Athlon XP spec and pinout (couple of them are PICD# and also missing VID#3 set high as recommended by Athlon spec)
- I bought a one channel bench PSU, sent 5 and 3.3 volts to ATX socket and checked if anything getting hot: especially south bridge Nvidia nforce2, north bridge ( I couldn't remove heatsink from it , I guess it's thermo-glued) and that ITE multi-controller. 5 volts was fine with just 0.5 A consumption, however 3.3 showed 1A consumption and that NVidia southbridge got suspiciously warm but still not blazingly hot though.
- I read somewhere (maybe in PC@LIVE's topic ) that to perform an additional check of a southbridge one needs to measure the voltage drop on USB ports: red probe on the mobo's ground and black probe on the data USB pins. All of those showed 0.7 which seems to be ok.
So I'm stuck now.
Being an incompetent idiot I have no Idea what to do next. And I hope that maybe someone here could gimme a hint of what might be a reason for mobo to fry CPUs so easily?
I guess if it was a short then at least some of MOSFETs or inductors voltages would show nothing. All socket pins are fine: I didn't spot any shorts there either. I recon when I power the board on the CPU starts consuming an enormous current and fries itself quickly but why ? Could southbridge be a reason (I guess unlikely) ? Maybe northbridge (but I have no idea how to even check that)?
Reply 1 of 49, by Ujeen
I apologizes for all those typos above, but I can't edit my own topic for some reason (probably because I'm Newbie still)
Reply 2 of 49, by butjer1010
I don't have a clue what could cause this problem, but i will write anything so i can see what the real masters here has to say about this weird thing 😀 Now it will leave me this topic in my posts 😀 I'm curious to see what happened here?
Reply 3 of 49, by weedeewee
I once recapped an asrock ? ecs? doesn't matter socket A board and ended up with the same problem. all voltages measured ok, yet two cpus fried on it.
I had to recap it since the old caps were bulging and causing instability. unfortunately after the recap the board fried two cpus.
Never dug deeper into the reason why.
Do not ask Why !
Reply 4 of 49, by PC@LIVE
Hi, I'm very pleased that you read what I wrote, just to clarify, I have several boards under repair, unfortunately I can't fix them all, both because I have limitations due to the equipment, and because I don't have knowledge of the circuits and components, I manage to do what I can, but I don't do it as a profession, just as a hobby.
Looking at the photo of the CPU, it is definitely overheated (and therefore no longer functional, almost 100%).
But from memory I remember a CPU that was very hot, trying it in one MB, but in another MB it works and doesn't heat up.
There will probably be a shorted PIN, there are not only the I/O and VCore voltages, I advise you to measure the voltages on all the mosfets (or regulators), they usually have three pins, if you measure those of the VRM, one of the three The PIN should be around 1.5-1.8V, if it is more than 2V, the problem may be there.
But there could be something wrong, for example if it has jumpers, check that they are all set correctly, or that they are all there, finally a careful visual check, make sure there are no tracks or broken SMDs.
If you want you can put the voltage of the three PINs of each mosfet (or regulator) here, maybe there is some anomalous voltage.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 5 of 49, by Ujeen
Thanks a lot for answering, guys.
PC@LIVE wrote on 2024-11-11, 20:06:
PC@LIVE, yeah I've been planning to remeasure everything again. I suspect that if the issue is with either of the bridges then I simply won't be able to confirm that without replacing those. I wish there was a schematic for AU31 but it's too old and people didn't bother to digitize schematics back then 🙁
Reply 6 of 49, by PC@LIVE
It occurs to me that those CPUs are quite easy to fry, certainly the first one was fried due to the lack of the heatsink, but the second one could have fried because you have to put a bit of thermal paste on the die (the little square or rectangle in the center of the CPU ), without thermal paste it is possible that the heat will not be dissipated, the consequence being burning.
I saw the photo and in fact it has very few jumpers, so I think that if it does not have values ​​stored in the BIOS with overvolts, the only problem could be a missing or faulty SMD, which causes an overvoltage in one or more pins of the socket, at least I think that is the most likely thing
Reply 7 of 49, by Ujeen
Makes sense , yeah , But I had a new thermo-paste applied before turning everything on again. Also I forgot to mention I bought a programmer and read the motherboard's bios to see if it's ok. It was ok but still I flashed the new one from theretroweb site.
Reply 8 of 49, by Ujeen
I will keep digging. how many more CPUs are gonna fry before I fix this mobo or give up...
Reply 9 of 49, by weedeewee
Ujeen wrote on 2024-11-11, 20:41:
How many more cpus do you have ?
Did you make the markings on the capacitors ?
Do not ask Why !
Reply 10 of 49, by butjer1010
Put only Athlon XP on this board (they should turn off when the temperature goes to 85 or 90)....
Reply 11 of 49, by Ujeen
weedeewee wrote on 2024-11-11, 20:43:
only two fried ones 😀 but ordered two more... but I guess this is a bad idea...
Yeah my markings 😀 those were looking suspicious 😀
Reply 12 of 49, by Ujeen
butjer1010 wrote on 2024-11-11, 21:03:
Noted! But I think both of them were XP , this didn't save them ...
Reply 13 of 49, by butjer1010
Ujeen wrote on 2024-11-11, 21:13:
Then is not overheating the problem i guess....
I have never fried Athlon XP, even without cooler... It should turn off after 90 degrees
Reply 14 of 49, by BitWrangler
There's a thermal diode on later Socket A but no idiotproofing, nevereverevereverever power them without a heatsink on, this is what happens.
Reply 15 of 49, by Ujeen
butjer1010 wrote on 2024-11-11, 21:18:
then only short can lead to this .. which I can't find still 🙁
Reply 16 of 49, by Ujeen
BitWrangler wrote on 2024-11-11, 21:22:
yeah I agree, but the second time it had heatsink+ fan on , working. Got fried same fast: couple seconds and done !
Reply 17 of 49, by momaka
Socket A builds are probably the most tricky of all, especially the part with the cooling/heatsink.
Are you 100% positive that when you installed the 2nd CPU with its heatsink that it was making proper contact with the CPU core/die? If the heatsink was used, there's always a chance the clip could be bent and/or not clamping the heatsink all the way. I just ran into a situation like that last week while testing an SV266A mobo. Luckily, I caught this way way before attempting to power up the board. In my case, the clip for the heatsink was original, but it just did not provide any tension on the heatsink at all. Had I powered it on like that, my CPU would have been fried. Luckily, I had some spare retention clips that fit and put proper pressure on the heatsink. With that, it was fine (despite me actually always being a cheapskate and re-using old... but not dry.. thermal compound from another CPU.)
Keyword here: *should*
Reality: they usually don't and burn right away.
It's been proven though: that thermal diode is way too slow to act when there is no heatsink installed on the CPU. Now if a heatsink is installed, but say the CPU fan is stuck, disconnected, or the heatsink is clogged with dust... that thermal diode *might* actually work to save the CPU. But don't count on it.
As many as it takes? For science. You monster! 😉
At least try going with some less-rare CPUs, so you don't piss off the collectors. 🤣
If the board supports them, maybe try a low-end ceramic chip Duron - these are, as the name might imply, a little more Durable. They are also lower TDP, so less chance they will fry instantly if the heatsink is not 100% right on the die.
BTW, I looked at the pictures on TRW, and this motherboard appears to use a synchronous buck VRM for the CPU, meaning it *should* be pretty hard for the board to fry the CPU, even if there was a shorted MOSFET (which I don't think is the case here... yet?) In any case, just to (roughly) rule out any high-side MOSFETs being bad, check resistance to ground on all of the pins in the 4-pin 12V CPU power connector. Two of those pins will be ground and should show a short circuit, but the other two are for the 12V rail and should show a relatively high resistance (KOhms range, at least.) Do this test with the PSU disconnected.
Speaking of the PSU...
Have you opened it up to check for bad caps there? I had someone send me a socket A board before that was completely fried - both the RAM and CPU were fried. Turns out, the PSU was a decent build but had a ton of bad caps, outputting ripple so high that it was killing stuff left and right. How the chipset managed to survive, IDK. But the RAM stick and CPU were gonners (probably the died before the chipset, saving it from the PSU.)
Reply 18 of 49, by butjer1010
Of course he will put the heatsink on it, he's not an idiot!!! Who mentioned that it will not "burn" without cooler?
Same answer....
[/quote]
Durons are the socket A CPUs that burns right in seconds when the fan stops spinning!!! What gives You this funny idea that he needs to use Durons???? That is the only reason i suggested him XP Athlons, because they have this thermal diode that Durons don't have! In nineties Intel had the comercial with Durons (if You remember those times, don't know when were You born), where they made fun out of AMD because of that reason. They used Duron in comercial, and they stopped the fan! After few seconds, the smoke came under the cooler, and they done that with Intel pentium also, but the pentium kept working fine! This was their way to people buy intel instead of AMD. So AMD made XP (extra protection) Athlons after that "fiasco"!!! They will not burn in second if the fan is problem....
After all he wrote up there, after all the things he has done, i think he is capable to put the cooler right, don't You think? Don't beleive the problem is in cooler, but that's my opinion....
Reply 19 of 49, by momaka
butjer1010 wrote on 2024-11-14, 21:54:
Uhm... you did. Or is that not your quote above? 😁
Sure.
Care to show proof?
Laws of physics (specifically, thermal transfer and thermal mass) simply don't work that way.
Stopping the fan for a few seconds won't do shit to the CPU, so long as the heatsink is still properly attached to it. It will take a good minute or more before the temperatures finally rise high enough to kill the CPU. That's because the heatsink has thermal mass, and it takes time to heat that up.
So NO, there's NO WAY the CPU will burn instantly IF the CPU heatsink is installed properly, regardless if the fan is running or not.
And so what?
As I mentioned, these thermal diodes aren't that good at reacting to over-temperature. If you're so trusting in them, why don't you show how that works with one of your own Athlon XP builds? I know I'm not willing to do that, because I've worked in the computer repair business long enough to have seen more than enough examples of how those thermal diodes specifically in socket A CPUs exactly don't really help more than anything else.
As for the reason I suggested low-end Durons (600-900 MHz models): they have a much lower TDP compared to Athlon XP. For example, the 700 MHz Duron Spitfire has a typical power consumption of ~29 Watts and a maximum consumption of a little over 30 Watts. That means this CPU will be spitting out about 30 Watts of heat, tops. For the 900 MHz Duron Spitfire, that's about 40 Watts max. Now take O/P's Athlon XP 2100+: assuming it's the Palomino model, it has a typical power draw of about 65 Watts and a maximum power draw of 72 Watts. This is more than twice the heat dissipation compared to the 700 MHz Duron. So if using the same heatsink (with a stopped fan... or maybe just a badly clogged heatsink with dust), the 2100+ will be much quicker to overheat than both the 700 MHz or 900 MHz Durons. It's simple physics, and that's all there is to it.
No I don't remember that commercial (was there even one?), but I do remember the Tom's Hardware video from back in the day (mid 2000's) where they did this experiment with a Pentium 3, a Pentium 4, and two socket A CPUs (IIRC, one was a ceramic chip Athlon and the other a newer FCPGA Athlon/XP.)
In any case, stopping the fan for a few seconds will NOT damage the CPU - that's just myth / bullshit if such thing was ever shown in a commercial. Now removing the heatsink entirely from a socket A CPU or just not seating it properly on it, that surely will burn out the CPU in seconds.
Not saying O/P is not capable of putting on the cooler right. But I have worked long enough in the electronics repair business to know that shit happens all the time and can happen to anyone, regardless of experience level. In my case as mentioned with the SV266A socket A motherboard that I was testing last week, the cooler retention simply was faulty and did not clamp onto the CPU properly anymore... though from a distance, it looked totally fine. It wasn't until I grabbed the whole motherboard by the cooler and noticed that it's actually wobbly and not tight / firm against the CPU. Not exactly sure how that happened, but I verified it several times. The retention spring was somehow damaged / bent out of shape. If I wasn't always double-checking everything like I always do, that CPU on the SV266A motherboard would surely have burned out.
Having an opinion is fine. But when it comes to troubleshooting, I like to work with facts only. So I don't take anything for granted until categorically verified.
