First post, by Locutus
Hi!
I wouldn't be myself if I didn't try to save this piece of junk...
The case of the drive was open, but inside is clean and platters are in perfect condition.
The main problem (so far) is missing piece of signal tape with plug 🙁
Can somebody provide me with the picture of the plug, so i can fugure out how signal lines from the tape are connected to the plug ?
I'll try to solder flexible cables to the tape to see if the drive shows any signs of life....
