First post, by Shponglefan
I'm working on repairing this Socket 5 EFA P54CNPCI motherboard.
The motherboard had its regulator and heatsink removed (presumably by scrappers). The markings on the board indicate an LT1084 regulator was used.
In looking up the LT1084, there are both adjustable regulators and fixed voltage (including 3.3V). According to the data sheets, markings on the part should be LT1084CT (adjustable) and LT1084CT-3.3 (3.3V fixed). Unfortunately I can't find any pictures of this motherboard on the web, so I don't know the specific part used.
In looking up other Socket 5 boards on the retro web, I notice both the ASUS PCI/I-P54NP4 and Gigabyte GA-586IP use an LT1084CT part, which seems to be the adjustable regulator. I'm wondering if the same would apply to this ECS board?
Retroweb links:
https://theretroweb.com/motherboards/s/efa-p54cnpci
https://theretroweb.com/motherboards/s/asus-pci-i-p54np4
https://theretroweb.com/motherboards/s/gigabyte-ga-586ip
The attachment EFA P54CNPCI motherboard.jpg is no longer available
The attachment EFA P54CNPCI regulator board location.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 24, by DaveDDS
Do you know what sort of heatsinc? Did it cover the part?
If you're lucky you might be able to find an image of that exact board and read type type of regulator.
(I googled/images the "P54CNPCI" and what images I saw didn't seem to be the same board. Perhaps there are others IDs on it you
can use to refine a search)
Failing that, I'd try to figure out what it's powering to see what voltage it needs to produce.
Also looking at LT1084 specs you might find a difference that would help identity it
(not very familiar with that one, but traditionally fixed regs have a control signal that it grounded,
while var-regs usually have some sort of adjusted control - perhaps you can see how it's connected
with power-off (ground .vs. not should be pretty easy)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 2 of 24, by TheMobRules
The three holes (from left to right in your picture) should be Vin, Vout and GND (in case of a fixed reg.) or ADJ (if it's the adjustable version). So it should be easy to check if the third pin is connected to ground or not. If it is intended for and adjustable regulator that pin should be connected between two resistors that work as a voltage divider.
Reply 3 of 24, by Horun
Yes If pin 1 (closest to board edge is Vadjust) goes to center of those two 1/4 watt resistors R182 and R183 then the variable Vreg is what you want.
Doing some simple math off this datasheet https://www.analog.com/media/en/technical-doc … ts/108345fh.pdf
The Volts out be about 3.5v output which would work for both standard and VRE cpu's.
Those resistors are 124ohm 1% and 315ohm 1% which tells me they should be for a Vreg or else 10% would be good enough....
Reply 4 of 24, by Shponglefan
Thanks for the information. I checked the continuity and the ADJ pin is not connected to ground. The regulator is connected to R182, R183.
Based on the markings, those look like they are supposed to be 124 ohm and 215 ohm. I measured them and they reported ~119 ohm and ~202 ohm respectively. Based on the datasheet, this should yield a voltage of ~3.3V.
I installed an LT1084CT regulator. But when measuring it, it's outputting a perfect 5V. I happened to have a second LT1084CT , so I tried swapping it just to make sure, but the second one outputted the same 5V.
I even tested using a 390ohm resistor on a VCC pin in the CPU socket just in case it needed some load, but it still was reading 5V.
I'm a bit confused as to what is happening here. I'm also concerned that I just shot 5V through VCC that should only have 3.3V. Not sure if I might have just damaged some components in the process, though it was only powered up a couple seconds in both tests.
Is it possible these are fixed 5V regulators that are somehow mislabelled? Is there something else going on with the circuit that is forcing it to 5V?
Reply 5 of 24, by TheMobRules
Weird... only thing I can think of is the regulator output being shorted to the +5V input on the motherboard itself. Some 486 boards with voltage autodetection do this to switch between +5V and +3.3V depending on the VOLDET CPU pin, but it doesn't make much sense on a Socket 5 board.
If it's not shorted on the board, it must be a problem with the regulators. Where did you get them from? I've heard about some fakes being sold on eBay or AliExpress.
Reply 6 of 24, by Shponglefan
TheMobRules wrote on 2024-11-13, 19:14:
Digikey. I would hope they would be legitimate.
edited: I just did the acetone test on the printing on the regulator and it didn't rub off. And it doesn't show any signs of being sanded / relabelled.
Reply 7 of 24, by TheMobRules
Yeah, if it's from DigiKey it should be legit.
If you have some resistors and a couple of caps you can test the regulator on its own, there's a simple example circuit on the datasheet.
I would try to remove the regulator and check if pins Vin and Vout are shorted on the board. Also, there could be a cap (tantalum probably) between ADJ and ground, if that one is shorted it will cause problems with the regulation. Also check the caps between Vin/Vout and ground for shorts.
Reply 8 of 24, by Shponglefan
TheMobRules wrote on 2024-11-13, 19:33:
That's a good plan. I'll try building a basic circuit and see how these regulators actually work.
I had tested the pins prior to installing it. None of them are shorted. And when I measure resistance across the pins, it's what I would expect in relation to the two resistors.
I checked the surrounding caps and didn't find any shorts either. I'll keep probing and see what I find. Worst case, I might try swapping some different resistors in just to see what happens.
I also acquired a 3.3V fixed regulator, so I'm wondering if I could modify the circuit to use that instead.
Reply 9 of 24, by TheMobRules
Shponglefan wrote on 2024-11-13, 21:41:
Yes you can! Of the resistors that adjust the output voltage (R182, R183), remove the one that connects to Vout and replace the one that connects to ground with a 0 ohm resistor (aka just a jumper wire). That way, pin 1 of the fixed regulator will be connected to GND as expected.
Reply 10 of 24, by Shponglefan
The mystery deepens!
I went ahead and removed the resistors, soldered a jumper wire, and added the 3.3V fixed regulator.
Still 5V!
The attachment EFA P54CNPCI still 5V.jpg is no longer available
I'm highly confused by this point. So I removed the regulator and re-tested the pads.
This is where I realized my mistake. In testing the pads, I had tested each of them to ground and confirmed that none of them are shorted to ground. But I didn't test to see if Vin and Vout were shorted to each other.
In testing those, they do appear shorted. It's not a dead short, as I get a 4 ohm reading. Evidently voltage from the 5V rail is passing through somewhere on the board to Vcc. In measuring both Vin and Vout on the regulator, Vin is slightly higher voltage than Vout. So this seems to make sense.
Now the question is what is connected to both the 5V rail and Vcc? If I can find the culprit, I can remove it and see if that short disappears.
Reply 11 of 24, by Shponglefan
After doing a bunch more testing (including trying the 3.3V regulator), it appears that 5V is being fed from the 5V rail into Vout.
Could it be the case that it's somehow switching to 5V in absence of a CPU? Is there a way to determine if this board has some sort of voltage auto detection?
Reply 12 of 24, by kagura1050
Can you take a photo of the back of the board? That might give us some clues.
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
Timezone : UTC+9
Reply 13 of 24, by Shponglefan
kagura1050 wrote on 2024-11-14, 00:30:
Sure, here you go:
The attachment EFA P54CNPCI motherboard back.jpg is no longer available
I did inspect it for things like solder bridges or other weirdness. But there is nothing odd that I have come across.
Reply 14 of 24, by TheMobRules
Can you try removing the cache chips and see if the short from Vcc to 5V persists? At least on my Neptune boards these are 3.3V chips that are powered by the same rail as the CPU. Maybe one of those went bad and is causing the problem.
I believe the 430NX chipset does use 3.3V for some signals but the power supply is 5V and it should be 5V tolerant on the signal pins as well.
Other things to look for: resistors/diodes gone short, accidental bridges.
Reply 15 of 24, by Shponglefan
TheMobRules wrote on 2024-11-14, 01:30:
I tried removing all ICs (cache, BIOS, clock chip) and the issue persists.
I've been probing various components (resistors, caps, etc.) and haven't found anything yet. Nor I have I come across any bridges, though I probably need to do a detailed look under the microscope.
Reply 16 of 24, by Shponglefan
How risky would it be to insert a Pentium CPU to test? Maybe this is just normal for this board and that it might drop the voltage with a CPU inserted, while for some reason outputting 5V in absence of one...
Or is there a way to spoof CPU detection in lieu of an actual processor?
If I had a dead Pentium to test, I'd do that, but as far as I know all of mine are functional and I don't really want to sacrifice one on this board.
Reply 17 of 24, by Tiido
you can try just a LED or a small value resistor (22...100ohm) as a dummy load. Some regulators need some load before they start regulating, although you measured a low resistance connection between input and output voltages of the regulator which seems unusual...
Reply 18 of 24, by Shponglefan
Tiido wrote on 2024-11-14, 02:24:
Does it matter which pin it goes on? I tried a resistor previously one of the VCC pins, and it didn't change the output voltage.
Reply 19 of 24, by kagura1050
I looked at the photos of both sides and traced the wiring. I couldn't find anything suspicious.
By the way, what I find very strange is that even though you have shorted the 5V line and 3.3V line many times, nothing has caught fire/smoke (not even the wiring or the regulator). . I think this indicates that there is a very strong short circuit or that the regulator is not working for some reason (GND is floating, etc.).
Timezone : UTC+9
