HaswellCertifiedLvr wrote on 2024-11-16, 23:42:
Hello all, just acquired an old Sony Vaio VGC-RB30 computer off the marketplace and doing some upgrades on the PC for some old Windows XP gaming.
From what I've saw at https://www.elhvb.com/mboards/oem/sony/VGC1.html, it does have a new BIOS enough to support the newer Pentium 4 processors with 2MB L2 cache (EV91510A.04T.0062.2005.0811.0305) however my system came with an older BIOS which I assume was the BIOS at system's release by March, 2005 according to Newegg (0022.2004.1208.1651).
Is there a BIOS update for this system, or can I just crossflash it with a retail Intel BIOS considering the board is just basically a rebranded Intel D915GAG (Augsburg) board?
There is a (newer?) BIOS dump for the Sony board here - https://www.driverguide.com/driver/detail.php … 74979006fef10be - though no info on what this version provides.
"Comments:
Sony Electronics VGC-RB42G Driver. This is the original BIOS for the Sony VGC-RB42G using the 915GRO motherboard. I you accidentally flash with the Intel OEM BIOS and want to change back to default, this will do it! Sony does not have this BIOS on their site for some reason and so-far I've noted it being IMPOSSIBLE to find, so I saved mine before modifying."
You can sort of track likely changes through the Intel-version release notes (these are to April 05, the last release being Feb 06)...
The attachment EV0444P.pdf is no longer available
