First post, by apfel
I get some crackling noise in some not all games in Windows XP.
In UT99 when I switch between EAX Support and non EAX the crackling only apears in the EAX Support.
Are there any recommended drivers for this card which can eliminate the crackling?
I tried the original XP drivers and the drivers from https://www.vogonsdrivers.com/getfile.php?fil … 220&menustate=0 but the crackling is present in both drivers.
Reply 1 of 3, by SuperDeadite
Dumb question, but are you sure the volume isn't peaking? Try lowering volume on both Windows and in game mixers.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 2 of 3, by leileilol
When I think Live crackles, I think of VIA's PCI bus
so uh
do you have a via chipset
Reply 3 of 3, by apfel
SuperDeadite wrote on 2024-11-20, 00:21:
All volumes are turned to the mid sections.
leileilol wrote on 2024-11-20, 02:01:
No Via-Chipset is present in the system. It's the linked system and all on board components except the LAN port are turned off. https://theretroweb.com/motherboards/s/gigabyte-ga-8i915pmd
