First post, by bimole
Hi,
I'm following up my investigations into the Wavestream SoftSynth, the sounds that rocked my youth... For those who want a history I refer you to this post : Hearing for this mighty Packard Bell GM softsynth!
I want to install the Packard Bell Sound 16C SRS sound card (with AZTECH AZT2320 chip) in another system, in this case a Super Socket 7 platform.
Here is a photo of the sound card:
FYI, on my old Packard Bell PC, the machine in which the sound card was originally installed, Wavestream SoftSynth works without a problem in these 3 cases:
- With an original Packard Bell ‘MASTER CD’ restoration
- With an installation of Win95 OSR2.5 vanilla and using the MASTER CD drivers
- With an installation of Win98 SE vanilla and using the MASTER CD drivers (even if Windows automatically installs WDM drivers, it is possible to force the VXD drivers from the MASTER CD afterwards).
This is a Pentium MMX 266 with 64MB EDO RAM, an Intel 430VX chipset and an S3 Trio 64/V+ video controller integrated into the motherboard.
On the SS7 platform, I can't get the Wavestream SoftSynth to work with the Packard Bell Sound 16C SRS sound card.
The system is as follows:
- ASUS P5A rev 1.04
- AMD K6-2 450MHz
- 128MB SDRAM
- HDD SATA partionned 10GB for the system and 20GB for the data, with IDE/SATA gateway
I tried the following configurations:
- Restoration with the MASTER CD (it is possible to trick the installation program and restore on any machine...)
- With an installation of Win95 OSR2.5 vanilla and using the MASTER CD drivers, with FIX95CPU patch for processors that are too fast
- With an installation of Win95 OSR2.5 vanilla and using the MASTER CD drivers, reconfiguring the processor to 166MHz and 66MHz FSB.
- With a Win98 SE vanilla installation and using the MASTER CD drivers.
None of these configurations work: MIDI sounds don't work (error ‘MMSYSTEM002 / device out of range’ when I want to play a .mid file), Windows sounds are completely broken (clicks, white noise...). The only solution: disabling Wavestream SoftSynth in the Device Manager. In this case, the FM synth works and so do the Windows sounds.
I should point out that Wavestream SoftSynth works with another sound card compatible with this SS7 system (HP Riptide with Rockwell RACC010 sound chip). I should also add that I encountered the same problem on an Intel 440BX platform with a Pentium II.
So I'm leaning towards incompatibility of the Sound 16C SRS sound card with non-Packard Bell hardware. It's not an OS problem either, since on the Packard Bell machine the Wavestream SoftSynth works on Win95 and Win98.
Is it possible that Packard Bell has locked out the use of the sound card with its very conventional hardware?
I enclose below the drivers from the MASTER CD if anyone here has the skills and kindness to examine them to find a possible cause.
https://drive.google.com/file/d/1cWBIRpXTczr- … ?usp=drive_link
Your help is very appreciated!
Cheers,
JB
