First post, by d00mo
I am trying to get this motherboard to work, but about to give up... but before doing that I want to reach out here (again) for any additional ideas.
This motherboard started before, but failed during startup (normally during memory test). One of the things that was pointed out previously by helpful members here was that one of the cache chip socket was empty, and also that the ones there were installed were a mix of brands and different speeds. So I decided to change them all and ordered a bunch of W2457AK-15 chips from AliExpress. I tested them all with my T48 programmed and kept only those that passed the test in Xgpro.
However, it is not booting at all. The PSU fan is turned on, and I can feel the CPU is getting hot, but I get no picture or POST/beep signal.
I have consulted the manual and installed both RAM (one single-sided 8MB in SIMM 1) and Cache memory accordingly.
Any ideas what can be wrong?
