First post, by Massimo_1971_2005
Hello, everyone. I am a new subscriber. My name is Massimo and I am writing from Italy. I ask for help because After an installation of Windows 98se I can't install in other hard disk any windows version anymore. Immediately after launching the setup some strange character appears on the screen and it changes the video mode from text to graphics (I assume) and then exits the setup. I attach image. Greetings to all.
Translated with DeepL.com (free version)
Reply 1 of 2, by PC@LIVE
Massimo_1971_2005 wrote on 2024-11-26, 19:46:
Hi, welcome 🤗
I can't tell you what causes the problem you have, but I suggest you try to start other OS, just to understand if it's a PC or disk problem, I can imagine it's a disk problem, maybe a re-installation would solve it?
But first I would do some tests, I would use a floppy 💾 DOS, and I would try if it works, from there maybe I would use a diagnostic program, or alternatively Phil's benches, with those you can see if the PC works, in case the problem would be in the disk.
Keep us updated if you can make progress or for anything.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 2 of 2, by Massimo_1971_2005
PC@LIVE wrote on 2024-11-26, 21:23:
Hi, welcome 🤗 […]
Hi, welcome 🤗
Thanks for the suggestions. I did all the tests and actually at the memory test it was freezing. I removed all the banks and put them back in. Then I reset the cmos and now everything works perfectly. Although initially I was very worried because after these operations the pc would not boot. I was afraid that I had caused a short circuit.
