diy adapter
First post, by bucket
The IDE to CF adapter I bought unfortunately only takes floppy power. I could buy a berg to molex adapter for cheap... Or I could cannibalize a broken PSU for free.
I shouldn't need anything more than wire cutters and electrical tape, right? As long as the lines match?
Reply 1 of 3, by wierd_w
Solder is vastly preferred, as is heatshrink tubing.
Reply 2 of 3, by kmeaw
You can use solder heatshrink connectors that are used for field repairs and can be found in car shops.
Just insert a clean stripped wire into both ends and heat it up with a lighter - solder would melt making a stable connection and heatshrink would shrink, isolating and mechanically protecting the connection.
The attachment 81Z+zCkDy2L._AC_SL1500_-3657557911.jpg is no longer available
Reply 3 of 3, by bucket
I see.
Well, If I HAVE TO spend money, I'm just buying the adapter.
