Dmetsys wrote on 2024-11-27, 14:30:
That's only applicable if you are using browsers like K-Meleon. If you are not browsing on 98 SE, you don't need KernelEx.
Personally, I don’t really browse the web on Windows 98SE. Except for reading vintage HTML sites or docs on CD.
I'm rather interested in electronics and Windows 9x allows playing with i/o ports.
You know, soldering stations, breadboards, through-hole components, transistors, relays, microcontrollers such as PIC16F84A or Arduino/ATmega328p, parallel and serial ports.
The old school stuff. Some applications were written in VB6, still. Atmel AVR Studio 4 is vintage soft, too.
With help of KernelEx/unicows/gdiplus, a lot of Windows XP and Vista era programs can be run on Windows 98SE, alongsude of the classics.
Some emulators and codec packs, too, which is a nice bonus.
That's convenienant for my Compaq Armada laptop, which runs Windows 98SE and is a bit too old for XP also.
Edit:
 I would highly recommend making a backup before trying/testing something new, next time.
That's a good idea. Personally, I'm using Acronis True Image 7 to 10 inside of the VMs.
True Image 7 can be installed on Windows 98SE, still, I believe.
Though I'm rather using the live medium here (ISO). If I have two HDD images mounted, I can copy over the content from one image to another.
It's helpful with VM images that need HDD files different disk IDs or if fixed-sized HDD images are used.
