GPU Repair
First post, by Methanoid
Hi
I have an old Quadro FX4500 which refuses to display any picture but is detected, drivers install fine and it can be flashed so seems to function other than this. I suspect the problem is caused by an "exploded" (absent) component on the PCB and have no idea how to tell what it is or what value so I can replace it. I cannot see any values on it and even work out WHAT it is! Photos below.
https://ibb.co/dMFJMxT
https://ibb.co/BN7WLZK
https://ibb.co/QJfFPJB
https://ibb.co/W5LK7dk
https://ibb.co/tXSpwSz
Grateful for any help
Reply 1 of 2, by elszgensa
First off - You weren't kidding when you wrote "exploded". Components don't do that for no reason, so even if you find a replacement, you still have to make sure the rest of the board is well enough for that to not immediately kill itself too. It might've simply been hit and physically shattered, but best to make sure.
You didn't include a wide angle shot of the entire board, but from what I found online the missing part is close to one of the two DVI ports, and there seems to be a second triplet of identical components/circuitry for the other port. If your entire issue is caused by just this one missing part then I'd suspect it's limited to that port, and would move around when you swap in an intact part from the other set. Otherwise there might be even more wrong with the board. Does the other port work?
Also, did you try an analog cable instead of digital (if the card supports that - haven't checked), or vice versa? If just one of the signal types is affected, that'll help narrow down what the broken part did.
Reply 2 of 2, by sdz
That's a common mode filter. Before bothering to find a replacement, just solder two wires like this, and check if the rest of the card actually works:
The attachment Screenshot 2024-11-27 173916.png is no longer available
It's more likely that the filter is on the VGA lines than the DVI lanes.
