Other Os's?
First post, by Mpn
I read somewhere that i can put another Os on top of the emulated dos emulator. i'm kind of skeptical. does this work? Can i put win95 in it?
Reply 1 of 8, by HunterZ
Correct. Read the forum. Yes. No.
You can boot a real copy of MS-DOS (and probably PC-DOS/DR-DOS/FreeDOS/OpenDOS/whatever) from a disk image.
You can also boot Windows 3.1 in the CVS versions.
Win95 cannot be booted, although people have certainly tried (and made some progress). DOSBox is missing a lot of things that Win95 needs but that games don't, so don't expect it to be supported any time soon.
Reply 2 of 8, by skoll
I have a problem to boot with any floppy or iso image from freedos. The problem is that it starts until the first menu is displayed. With type in 1 for the item selction dosbox will crash with the message: "Exit to Error: Illegal option"
The command I use is "boot fdos1440.img -l a"
Whats wrong? 😢
Reply 3 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
despite hunterZ claims. I'm not sure that FreeDOS is supported (or has been tested at all)
I recall that
boot fdso1440.img should suffice. (no need to add -l a)
Water flows down the stream
Reply 5 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
I suggest you try the cvs of dosbox.
On the development forum are some details.
The boot code has been improved a lot.
Altthough I'm still not certain that freedos has been tested.
Reply 8 of 8, by DosFreak
Use Qemu.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
