First post, by negativebias
Hey all, I have an In-Win S500 ATX case from the late 90's. It's in perfect shape, has good hardware in it already, and I want to finish the build. However, I can't seem to mount 5.25 or 3.5 drives in it, because In-Win for this case used these sled brackets you attach to the sides of the drives so that you could slide them out of the front. Are these available anywhere? Are there alternative methods I could use to mount the drives?
