First post, by Machine Monarch
- Newbie
Wazup,
Trying out Windows 95 and 98 installs on my Toshiba Satellite Pro 430 CDT and the experience is very slow.
I mean sure, I don't recall the Windows 95/98 era being known for super fast speeds but I'm at a point where I can't even use the OS decently.
For example loading up a bunch of .xm or .mod files in modplay player will eventually have the computer stuttering.
You can composing music in ModPlug Tracker. Sound response is delayed when I hit the keys.
Count out WinAmp and I cant play games like Psygnosis Roller Cage... Browsing files is even slow.
Specs:
* 32 MB RAM
* CF Adapter with either
- Windows 95 on a SanDisk Ultra II CompactFlash @ 15MB/s
- Windows 98 on an Advantech SQFlash Industrial Grade 4 GB CF, SQ-P10S2-4G-CT2 @ 30MB/s
Super appreciative if anyone can point me in the right direction.
I just want to make some nice music on this piece of hardware. I've heard good things about the OPL3 sound chip!
Questions
1. What can I do to bring the speeds up? Better storage device? Perhaps a PATA SSD?
2. Would you recommend using DOS instead? If so, which DOS? There seems to be so many variants...
3. Any other good msuic tracker software you'd recommend? Adlib Tracker II or perhaps something else?
