First post, by jaggsy1986
Hi as the title Suggests I have an issue with this motherboard where once chipset drivers are installed, the PC Hangs at the point where it says starting windows 95 using either a sata to ide adaptor or compact flash to IDE. It works fine in safe mode and also works before I install chipset drivers on a new install. An IDE hard drive works fine with the chipset drivers installed.
The via chipset drivers are the ones off phils computer lab. Also installed ones off the motherboard CD to No avail.
My idea was to install operating system on IDE drive and use the compact flash on the 2nd IDE Channel to transfer games etc over.
