darry wrote on 2024-12-11, 00:03:Does it actually sound "OK" at least through the MIC out and does it play in stereo ? Is the volume really low? […]
My gut feeling is that the card (probably the mixer on tbe chip, more specifically) suffered some odd damage which is causing this, somehow.
I don't see how a driver issue could cause this (you could try under DOS to be sure) and that Yamaha chip and card date back to before jack reassignment was a thing.
The only other thing that springs to mind is that this is an oddball variant of that card with a slightly different layout that was factory paired with the wrong backplate. That would very much be a longshot, though.
It’s possible it could have suffered some odd damage. It did look slightly bent/skewed when I first put it in. 🫢😅
But yeah, it sounds perfectly fine in the Mic input. It can have some distortion/crackling if the volume in the mixer is at maximum. The volume dial isn’t even up very much either.
But I’ll try testing it out under DOS tomorrow. I’ve experimented with the speakers and cables, but nothing works if it’s in anything else but Mic. I even tried just the two speakers on their own. I took some pics of the backs of the speakers to double check I’ve set things up right. I wondered if I needed to connect a Left and Right cable in Line 2, but couldn’t get anything different there. And yep - tried re-installing the drivers, but, nada.
I just hope when I finally get the SC-55 set up, and hook it to the Line In (or Audio Out), that it works. 😕
The attachment IMG_3906.jpeg is no longer available
The attachment IMG_3907.jpeg is no longer available
The attachment IMG_3905.jpeg is no longer available
And I did try connecting the right speaker to In and Out, and the other cable in the opposite, and then into Audio Out and Line In, but no change.
OS: Windows 98 SE
CPU: Pentium III Katmai 450MHz (SL35D)/Pentium III Coppermine 933MHz (SL448)
RAM: SK Hynix 128MB 100MHz/Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/Geforce 128MB 4 MX 440
Motherboard: MSI-6156/Abit BE6-II
