First post, by DustyShinigami
- Oldbie
Hi
I seem to have run into a problem setting up a new secondary HDD. I had to replace my old D drive for something with more space. The last drive was about 10GB, this one is 80GB. This wasn't a problem before. I've totally forgotten what website/guide I followed and it doesn't look like I saved it. I was able to get the last HDD recognised and reformatted using fdisk. The BIOS recognises the new drive, but it looks like it recognises it wrong. It looks to list it as 33GB. 😮 And in Windows it doesn't recognise the drive at all. When I tried loading fdisk, it didn't appear to recognise any unallocated space or drives at all. Just the C drive. I'm not quite sure what to do. I did consider removing the IDE drive from the Device Manager so I could let it re-install/configure, but it won't allow me to do that with the Primary IDE or Secondary. Only the Master. But I don't want to run the risk of doing that in case it knackers things.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
