First post, by LeFlash
- Member
Hello,
i've been searching for the drivers of this card, especially windows (2k).
There seems to be nothing around.
Does anyone have the drivers?
kind regards
Hello,
kind regards
From this: https://web.archive.org/web/20000925122529/ht … s/nic/3c359.htm (note archive org really having issues today...)
File Name: 3c359b1x.exe Size: 736347 Date: 4/30/99
TokenDisk 1 for the 3C359/3C359B TokenLink Velocity XL PCI NIC V6.1
File Name: 3c359b2x.exe Size: 578842 Date: 4/30/99
TokenDisk 2 for the 3C359/3C359B TokenLink Velocity XL PCI NIC V6.1
83-1276-000 TokenLink Velocity XL Token Ring PCI NIC Version 6.1
From internals you need disk 1 for w98/2000
Think all the older 3com nic drivers/docs need to be archived.... here and at TRW.
Your setting up a token ring network?
You need to create a post on that!
I want to see as well.
I'm setting up FDDI right now - a cousin of token ring
legodude wrote on 2024-12-16, 00:20:I want to see as well.
Same here! I put a syskonnect and a 3c359 in a pcie to dual-pci-riser and also a 8port t1/e1 in pcie-slot of my second proxmox machine.
Now i can run win2000 or older linux for routing packets trough my retro network with different topologies!
BTW i found a complete archive of the 3com ftp:
https://downloads.bl4ckb0x.de/ftp.3com.com/3c359/
Everything there and the drivers are working.
edit: I also got my hands on some cheap cisco gear (2600, 7200 and 2921 router) - with all of the oldschool media cards fittet! Got the idea of the cisco-stuff by clabretro channel on yt.
Looking forward to play with this stuff!
